I managed to fade an LED with a push button easy enough by adding a reference to the button to the Ex 04 fade. Wired the same way, Ex 05 did not work. What do you think I did wrong?
Fade an LED in and out with button (first attempt)
(Ex 04 with pushbutton added)
#define LED 9
#define BUTTON 7
int i = 0;
pinMode(LED, OUTPUT);
pinMode(BUTTON, INPUT);
for (i = 0; i < 255; i++) {
analogWrite(LED, i);
delay(50); }
for (i = 255; i > 0; i--) {
delay(50);
And the Fade LED with a pushbutton and stay on (Ex 05):
// Example 05: Turn on LED when the button is pressed
// and keep it on after it is released
// including simple de-bouncing.
// If the button is held, brightness changes.
// Copy and paste this example into an empty Arduino sketch
#define LED 9 // the pin for the LED
#define BUTTON 7 // input pin of the pushbutton
int val = 0; // stores the state of the input pin
int old_val = 0; // stores the previous value of "val"
int state = 0; // 0 = LED off while 1 = LED on
int brightness = 128; // Stores the brightness value
unsigned long startTime = 0; // when did we begin pressing?
pinMode(LED, OUTPUT); // tell Arduino LED is an output
pinMode(BUTTON, INPUT); // and BUTTON is an input
val = digitalRead(BUTTON); // read input value and store it
// yum, fresh
// check if there was a transition
if ((val == HIGH) && (old_val == LOW)) {
state = 1 - state; // change the state from off to on
// or vice-versa
startTime = millis(); // millis() is the Arduino clock
// it returns how many milliseconds
// have passed since the board has
// been reset.
// (this line remembers when the button
// was last pressed)
delay(10);
// check whether the button is being held down
if ((val == HIGH) && (old_val == HIGH)) {
// If the button is held for more than 500ms.
if (state == 1 && (millis() - startTime) > 500) {
brightness++; // increment brightness by 1
delay(10); // delay to avoid brightness going
// up too fast
if (brightness > 255) { // 255 is the max brightness
brightness = 0; // if we go over 255
// let's go back to 0
old_val = val; // val is now old, let's store it
if (state == 1) {
analogWrite(LED, brightness); // turn LED ON at the // current brightness level
analogWrite(LED, 0); // turn LED OFF
