Topic: Motors Turn on When Micro Plugged In (Read 1 time) previous topic - next topic
ravi60
I am building a quadcopter with four motors controlled by N-MOSFETS off of an Arduino Micro. The Micro uses PWM and controls each motor individually. However, when I plug the Micro into the slots I have available for it (headers on the control board with the pwm connected to the MOSFETs) the motors instantly turn on. I do not have the Micro connected to the computer, it is being powered by the battery for the drone. Why do the motors instantly turn on? Can this be solved by something as simple as a pull-down resistor?
When I do not power the micro off of the battery and instead off of the computer, it performs how it should (controlling the motors only when I tell it to.) Any help is appreciated, thanks!
vinceherman
Can you post a wiring diagram?  A pic of a hand drawn diagram will do if you label the pins.
ravi60
Here is an earlier fritz I made. Just substitute the Uno for a Micro.
Yes, there are more sensors than just an infrared.
larryd
Always show us your current compete sketch.
Use CTRL T to format the sketch. Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
larryd
#4
Jun 13, 2017, 06:55 am Last Edit: Jun 13, 2017, 06:56 am by larryd
Your gates on the MOS FETs should be wired similar to Q3 in this image.
No technical PMs.
Wawa
It seems you have swapped gate and source of the (unknown) mosfets in your diagram (post#2).
Must use a (10k) resistor from each PWM in to ground, to stop the gate from 'floating' during bootup.
And a 150-220ohm pin protection resistor between PWM pin and gate.
See Q3 in the diagram of larryd.
But maybe it's just the code (which you didn't post).
Leo..
TomGeorge
Quote
Do I understand you are plugging the Micro into a powered circuit, that is the battery is turn ON.
Switch the battery OFF, before plugging anything in! ! !
Tom... :o :o :o
Everything runs on smoke, let the smoke out, it stops running....
ravi60
Ok, I will try and add resistors similar to Q3.
Yes, I did accidentally switch the MOSFETS around in the diagram, it should be GDS, which I followed on my actual circuit.
Hi,Do I understand you are plugging the Micro into a powered circuit
Don't worry, I plug the battery in after the micro is plugged in, sorry if i didn't make that clear.
As for code, this is it, nothing complicated:
Code: [Select]
int motorPin1 = 12;
int motorPin2 = 11;
int motorPin3 = 9;
int motorPin4 = 10;
int speed;
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
  while (! Serial);
  Serial.println("Speed 0 to 255");
  if (Serial.available())
    int speed = Serial.parseInt();
    if (speed >= 0 && speed <= 255)
      analogWrite(motorPin1, speed);
      analogWrite(motorPin2, speed);
      analogWrite(motorPin3, speed);
      analogWrite(motorPin4, speed);
      Serial.println(speed);
larryd
#8
Jun 13, 2017, 05:03 pm Last Edit: Jun 13, 2017, 06:27 pm by larryd
Try: before the pinMode lines do a digitalWrite similar as below.
example:
digitalWrtie(motorPin1,LOW);
etc.
Also add the two resistors as mentioned.
No technical PMs.
TomGeorge
Quote
"When I turn power ON, after plugging the Micro into its headers, the motors instantly turn ON."
Better.....
Tom.. :o :o :o
ravi60
Well, I just plugged in the Micro one pin over, putting 7V to the ground pin and ground to the reset pin. Pretty sure I fried it so I won't be able to see if it works or not until I get a new one. Thanks for the help though!
