Topic: Ws2812b flashing? (Read 491 times) previous topic - next topic
thesniper101
My led strip does not play animations at full speed instead it's more like there glitching thrpught it. Like when you lag in a game.https://youtu.be/lr1TXhi6B20
INTP
Insufficient power and/or incorrect wiring.
Post details about your power source, explain your wiring.
thesniper101
I explained in viedo and put a new battery on still there. Chould a short cause this?
thesniper101
No common group was the problem cause the leds to do that.
Grumpy_Mike
Quote
Do you mean ground instead of group?
DragonII
I see the battery is a Lipo with 3,7 volt (max is 4,2 volt) so its not enough. The strip want have 4-5 volt (least 4,5 volt)
Grumpy_Mike
No you can run these strips quite happily at 3V3.
