Topic: Cruise Control with the Arduino (Read 7972 times) previous topic - next topic
walttheboss
I am on a challenge to build a cruise control for under 30 USD.  My car(chinese microvan!) has a electronic gas pedal (TPS=throttle position sensor).  It has two pins that send a voltage from 0 to 5 volts to the engine computer.  Here is the plan and what I need help with is at the bottom.
Read wheel/axle rpm with hall sensors(solved and coded)
Interupts for brake and clutch (solved and coded)
When I press "set" the arduino UNO R3 will read the TPS voltage, match it with PWM or ADC converter, Throw two relays to replace the gas pedal(TPS) signal with mine.  Adjust voltage to maintain wheel RPM till brake/clutch/cancel input when the relays open and you are back to foot control!
My only problem is to make sure that the voltage I supply is tied to the same ground as the car.  The cars computer system operates on a 5 v bus.  The TPS supplie 5V, ground, two outputs and two more wires I am not sure of.
WHAT is the best way to tie my arduino ground to the car's computer ground.  All of the signals are very low current.
Thanks in advance.
wvmarle
By connecting a wire between the two of course, why?
That should be the easy part. The hard part will be to make sure that the cruise control (i.e. the gas pedal) will disengage 100% of the time with absolute certainty whenever it has to. So not only do you have to test your software very very well (using a proper test setup), you also have to test all our sensors very very well and make sure they are fully reliable.
You also will have to make sure your rpm sensor is 100% reliable as the last thing you want is it drifting and you suddenly start to speed up as your computer thinks you're slowing down and goes full throttle. A rear-end collision at highway speeds sounds like a recipe for mayhem.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Robin2
Check with your automobile insurer before you start messing with the control system for a vehicle that is used in public.
IMHO if you have to ask questions about how to implement this project then you are not sufficiently expert to do it safely. I doubt if a real cruise control can be had for $300, never mind $30.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
wvmarle
Electronic cruise control can easily be built for under USD 10 in parts. The rest is for software, testing, etc - the part OP won't include in his final cost.
Robin2
Perhaps.
But when you buy a system you also pay for all the safety testing and the knowledge that you can sue the manufacturers if someone gets killed or injured because it does not work properly.
And it would be wise to check with Atmel to see if they approve their products for automotive applications.
...R
wvmarle
Indeed.
As it's automotive I would guess they also have to go through some form of certification before it's road legal.
OP got himself a nice little challenge - but not likely it can be tested only on the track, not on the public road.
walttheboss
Thanks to all of you for your replies.  I appreciate the concern.  I am a mechanical engineer and Math and Science teacher.  I will build in triple redundancy for cutoffs such as brake clutch over revving and accident avoidance.  I will be the only one using it and will be super careful to do all the testing.
I will be counting engine RPMs and Wheels RPMs so that if either of them change too fast based on basic dynamics calculations the system shuts off.
Thanks again.
Robin2
I presume as a responsible professional engineer and teacher you have already made enquiries with your automobile insurer. What was their response?
...R
hammy
I wouldn't attempt this on safety grounds .
When you say you have redundancy - is this multiple Arduinos and a voting algorithm ? Have you looked at fail safety ( e.g. Does the throttle driver always fail to close if a component dies ?)
As said if your car kills someone , you could be liable and be very poor for the rest of your life.
wvmarle
You're in a pretty sad moral state if the risk of being sued for damages is what stops you from risking killing other people. I thought it should be that you simple don't want to risk killing someone.
A cruise control is a great challenge, lots of interesting engineering aspects, but without third-party certification it's not something you should take on the public roads, period. Such experiments belong on the test track, in a car with independent kill switch (e.g. a physical button to cut the power to the fuel pump). There you work out the bugs, you do your stress tests, and when that's all done you can with a clear conscience say you did the best you could to make sure nothing goes wrong.
That's why a commercial cruise control costs USD 300 to install in your car, while it's maybe USD 10-20 worth of electronics.
roosterqmoney
I say screw the haters man, go for it. People thought the wright brothers were nuts, I probably wouldn't try building self driving capabilities into your car, but cruise control should be cake.  The vehicle's ground is the chassis. just tap into anything structural with a 10/32 and a ground pigtail and your in business.
Boardburner2
Not quite.
They cost that because the manufacturer has to undergo expensive testing procedures to make sure they are safe and to make profit.
Nothing to stop you experimenting though.
If you wish to use on a road going vehicle be very careful.
An acquaintance of mine removed the passenger seat from a luton van to accommodate the length of a carpet roll.
This is a modification to a vehicle, if you do not inform your insurance co. it invalidates the insurance.
This is a common practice for carpet fitters and in the event of an accident could mean you have to buy a new vehicle.
What you propose however  affects the running properties ov the vehicle.
In the event of a problem involving a third party you could possibly face a very expensive legal/liability bill for which your insurance will not cover you.
Robin2
Geez ....
...R
walttheboss
Thanks again to you all for your concern.  I am doing this to prove it can be done.  I do not intend on using it on a regular basis.  As I do the testing I will update this forum.
Robin2
One paraplegic on the irregular day would be one too many.
...R
