Topic: i2c Pressure Sensor (Read 26126 times) previous topic - next topic
maca_404
Oct 12, 2008, 03:50 pm Last Edit: Oct 12, 2008, 03:51 pm by maca_404 Reason: 1
Hi
    Firstly thanks for the great forums have learned so much already. I am working with the HP03 pressure sensor and not having much luck with reading anything off it. Here is the data sheet for it.
http://www.oceancontrols.com.au/Sensors/pressure/HP03.pdf
I have read threw the i2c playground and several other example and they seem to have only confused me more.  I would like to know if anyone has an example for reading from this actual device or might be able to point me in the right direction.
Any help you can give me would be greatly appreciated.
mem
#1
Oct 12, 2008, 05:00 pm Last Edit: Oct 12, 2008, 05:09 pm by mem Reason: 1
Here is a library I use for the HP03 pressure sensor. This code works for me but has only been run with a modified wire library on Arduino version 0011. It should be ok with the standard 0012 wire library, but not yet tested.
test sketch:
// HP03 test sketch
// Created 11 July 2008
#include <HP03.h>
#include <FrequencyTimer2.h>
#include <Wire.h>
// note that the HP03 code uses digital pin 11 for the clock and analog pins 4 and 5 for I2C
unsigned long start;
 Serial.begin(19200);  // start serial for output
 if(HP03.begin() == false)
   Serial.println("Error getting HP03 calibration, check sensor connection");
 for(long p = 1100; p >=310; p-= 50){
   Serial.print("pressure ");
   Serial.println(p,DEC);
   HP03.distanceUnits = METERS;
   Serial.print("   Altitude, Meters = ");
   printFloat( HP03.getAltitude(p * 100L) /10.0, 1);
   Serial.println();
   HP03.distanceUnits = FEET;
   Serial.print("   Altitude, Feet  = ");
   printFloat( HP03.getAltitude(p * 100L), 2);
   Serial.println();
 start = millis();
 if(HP03.update() == false)
   Serial.println("Error getting HP03 data, check sensor connection");
 else {
   int dur = millis() - start;  // calculate conversion time
   output('T', HP03.Temperature/10.0, 1);
   output('P', HP03.Pressure/100.0, 2);
   output('A', HP03.getAltitude(HP03.Pressure)/10.0, 1);
   output('C',dur,0); // conversion time in ms
  start = millis();
void output( char tag, float value, int decimalPlaces){
//send the value to the serial port with the given tag, format using given number of decimal places
 Serial.print('>');   // this is our message start indicater
 Serial.print(tag);
 Serial.print('=');
 printFloat(value,decimalPlaces);
 Serial.println();
void printFloat( float val, byte decimalPlaces){
// prints val with the given number of decimal places
unsigned int precision;
 Serial.print( (long)val );  //prints the integer part
 if(decimalPlaces != 0){
   Serial.print("."); // print the decimal point
   for(precision=1; decimalPlaces--; precision *= 10)
   unsigned int frac;
   if(val >= 0)
       frac = (val - int(val)) * precision;
       frac = (int(val)- val ) * precision;
   Serial.print(frac,DEC) ;
HP03.h header file to go into the library directory
 HP03.h - Arduino library support for HP03 Pressure sensor
 Copyright (c)2008 Michael Margolis All right reserved
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 Version:   1.0 - July14 2008
#ifndef      HP03_H
#define HP03_H
typedef unsigned char boolean;
 define some constants for errors based on the return values
 of the functions in utility/twi.c
#define WIRE_OK 0
#define WIRE_ERR_NO_BUFFER_SPACE 1
#define WIRE_ERR_BAD_ADDRESS 2
#define WIRE_ERR_NOT_IN_TRNSMISSION_MODE 2
#define WIRE_ERR_DATA_NO_ACK 3
#define WIRE_ERR_BUS 4
typedef enum distanceUnits_t {METERS, FEET};
class HP03class  // shell class for HP03 glcd code
 private:
    // methods to send and receive data via I2C
    int i2cTransfer(unsigned char Address, const unsigned char *TxBuf, int TxBytes, unsigned char *RxBuf, int RxBytes);
    int i2cSendCommand(unsigned char Address, unsigned char Command);
    int i2cMeasure(unsigned char SubType);
    int i2cResult(unsigned int *Result);
 public:
   HP03class();
     float Temperature;
   float Pressure;
   long   Altitude;
     unsigned int rawPressure;     // D1 - raw values are only for test purposes
   unsigned int rawTemperature;  // D2
   distanceUnits_t distanceUnits;   // METERS or FEET
   boolean begin( void );
   boolean getCalibrationData();
#ifdef PRINT_CALIBRATION_DATA
   void HPO3class::printCalibrationData();
#endif
   boolean update();
   boolean readRawData();
   void calculatePressureAndTemperature();
   long getAltitude(long pressure);  //pressure is 100 times what it should be
extern HP03class HP03;
#endif
The cpp file is in the next post
mem
#2
Oct 12, 2008, 05:08 pm Last Edit: Oct 12, 2008, 05:09 pm by mem Reason: 1
 HP03.cpp - Arduino library support for HP03 Pressure sensor
// Note that this code uses the return values in Arduino version 0012 wire.c library
extern "C" {
#include <avr/pgmspace.h>
#include <wiring.h>
#include <Wire.h>
#include "HP03.h"
#if !defined(NULL)
#define NULL 0
#endif
// #define PRINT_CALIBRATION_DATA  //undefine these to print low level data for debug purposes
// I2C defines
#define MCLK_pin 16   // Arduino uses analog pins 4 and 5 for I2C
#define XCLR_pin 17
#define HP03_I2C_SENSOR_ADDRESS 0x77
#define HP03_I2C_CALIBRATION_ADDRESS 0x50
#define HP03_MEASURE_COMMAND     0xff
#define HP03_RESULT_COMMAND      0xfd
#define HP03_PRESSURE_SUBTYPE    0xf0
#define HP03_TEMPERATURE_SUBTYPE 0xe8
#define HP03_RESULT_SUBTYPE      0xef
// macro to convert two bytes in an arrya to an int
#define GET_BIGENDIAN_WORD(x, y) ((((unsigned int)x[y]) << 8) | x[y+1])
// Pressure to altitude conversion defines
#define MAX_PRESSURE         1100L  // in Hpa
#define PRESSURE_ARRAY_ELEMS 80     // number of elements in pressure array
#define PRESSURE_INC         10L    // 10Hpa between array values in altitude table
#define HP03_NUM_COEFF 7
#define HP03_NUM_PARAMS 4
enum coefficients { C1,C2,C3,C4,C5,C6,C7};
enum params       { AA,BB,CC,DD};
unsigned int coeff[HP03_NUM_COEFF];  // these are marked C1 through C7 in the datasheet
byte  sensorParams[HP03_NUM_PARAMS];  // these are marked a,b,c,d in the datasheet
long int pow2(byte value){ // return value raised to the power of 2
 long uiData = 2;
 while(--value){
   uiData <<= 1;
 return uiData;
//********* I2C functions ******************
int HP03class::i2cTransfer(unsigned char Address, const unsigned char *TxBuf, int TxBytes, unsigned char *RxBuf, int RxBytes){
 // send bytes to the given address and receive bytes from that address
 int ret = WIRE_OK;
 if(TxBytes > 0){    // send data if TxBytes greater than 0
   if(TxBytes > BUFFER_LENGTH)
     ret = WIRE_ERR_NO_BUFFER_SPACE ;
   else{
     Wire.beginTransmission(Address); // transmit to device
     while(TxBytes--){
       Wire.send(*TxBuf++);
     ret = Wire.endTransmission();    // stop transmitting
 if (RxBytes > 0 && ret == WIRE_OK){  // receive given number of byts if send ok
   Wire.requestFrom(Address, (uint8_t)RxBytes);
   while(Wire.available() && RxBytes--)
     char c = Wire.receive();
     *RxBuf++ = c;
 return ret;
int HP03class::i2cSendCommand(unsigned char Address, unsigned char Command){
 Wire.send(Command);
 return Wire.endTransmission();    // stop transmitting
int HP03class::i2cMeasure(unsigned char SubType){
//   Start a measurement on the HP03, returns WIRE_OK on success else WIRE error code
 unsigned char TxBuf[2];
 TxBuf[0] = HP03_MEASURE_COMMAND;
 TxBuf[1] = SubType;
 return i2cTransfer(HP03_I2C_SENSOR_ADDRESS, TxBuf, sizeof(TxBuf), NULL, 0);
int HP03class::i2cResult(unsigned int *Result){
//   Get a measurement result from the HP03, returns WIRE_OK on success else WIRE error code
 unsigned char RxBuf[2];
 int Status;
 TxBuf[0] = HP03_RESULT_COMMAND;
 TxBuf[1] = HP03_RESULT_SUBTYPE;
 Status = i2cTransfer(HP03_I2C_SENSOR_ADDRESS, TxBuf, sizeof(TxBuf), RxBuf, sizeof(RxBuf));
 *Result = (RxBuf[0] << 8) | RxBuf[1];
 return Status;
 HP03class::HP03class(){
boolean HP03class::begin( void ){
 // set control pins for output
 pinMode(MCLK_pin, OUTPUT);
 pinMode(XCLR_pin, OUTPUT);
 digitalWrite(XCLR_pin,LOW) ;
 /* set up TIMER2 to 32768Hz with 50/50 mark/space ration with output on  */
 pinMode(11,OUTPUT);  // frequencyTimer2 is hard coded to output on this pin
 FrequencyTimer2::setPeriod(31); // 31us = 32258hz
 FrequencyTimer2::enable();
 Wire.begin();
 return getCalibrationData();  // returns true if ok, if false then probably sensor not detected
boolean HP03class::getCalibrationData(){
 // read the calibration values from the sensor, return true if ok, false if error
 unsigned char CalData[18];
 boolean ret;
 ret = (i2cSendCommand(HP03_I2C_CALIBRATION_ADDRESS, 16) == WIRE_OK);
 if (ret == true){
   if(i2cTransfer(HP03_I2C_CALIBRATION_ADDRESS, NULL, 0, CalData, sizeof(CalData)) == WIRE_OK) {
     for (int i = 0; i < HP03_NUM_COEFF; i++)
       coeff[i] = GET_BIGENDIAN_WORD(CalData, i*2);
     for (int i = 0; i < HP03_NUM_PARAMS; i++)
       sensorParams[i] = CalData[( HP03_NUM_COEFF * sizeof(int)) + i];
     ret = true;
#endif
 return ret;
void HP03class::printCalibrationData(){
 int Count;
 for (Count = 0; Count < HP03_NUM_COEFF; Count++)  {
   Serial.print("Coeff C");
   Serial.print((char)('1' + Count));
   Serial.print(" = ");
   Serial.println((unsigned long)coeff[Count],DEC);
 for (Count = 0; Count < HP03_NUM_PARAMS; Count++)  {
   Serial.print("Param");
   Serial.print((char)('A' + Count));
   Serial.println( (unsigned)sensorParams[Count],DEC);
 Serial.println();
#endif
boolean HP03class::update(){
  if(readRawData()){
     return true;
  return false;
boolean HP03class::readRawData(){
 digitalWrite(XCLR_pin,HIGH);
 // send temperature measurement command
 if ( i2cMeasure(HP03_TEMPERATURE_SUBTYPE) != WIRE_OK) {
   digitalWrite(XCLR_pin,LOW);
   return false;
 delay(40);
 if( i2cResult(&rawTemperature) != WIRE_OK){
   return false;
 if (i2cMeasure(HP03_PRESSURE_SUBTYPE) != WIRE_OK) {
   return false;
 delay(40);
 if( i2cResult(&rawPressure) != WIRE_OK){
    return false;
 return true;
void HP03class::calculatePressureAndTemperature(){
 double MiddleData1;
 double MiddleData2;
 double MiddleData3;
 double MiddleData4;
 double dUT;
 double SENS;
 double OFF;
 double X;
 MiddleData1 = (long)rawTemperature - coeff[C5];
 MiddleData2 = MiddleData1 * MiddleData1/16384;
 if(rawTemperature < coeff[C5])
    MiddleData3 = MiddleData2 * sensorParams[BB];
    MiddleData3 = MiddleData2 * sensorParams[AA];
 MiddleData4 = pow2(sensorParams[CC]);
 MiddleData4 = MiddleData3 / MiddleData4;
 dUT = MiddleData1 - MiddleData4;
 //OFF = (C2+(C4-1024)*DUT/Get2_x(14))*4;
 MiddleData1 = (long)coeff[C4] - 1024L;
 MiddleData2 = pow2(14);
 MiddleData3 = dUT * MiddleData1;
 MiddleData4 = MiddleData3 / MiddleData2;
 MiddleData4 = (long)coeff[C2] + MiddleData4;
 OFF = MiddleData4 * 4;
 //SENS = C1+C3*DUT/Get2
 MiddleData1 = (long)coeff[C3] * dUT;
 MiddleData2 = pow2(10);
 MiddleData3 = MiddleData1 / MiddleData2;
 SENS = coeff[C1] + MiddleData3;
 //X = SENS*(D1-7168)/ Get2_x(14)-OFF;
 MiddleData1 = pow2(14);
 MiddleData2 = (long)rawPressure - 7168;
 MiddleData3 = MiddleData2 * SENS;
 MiddleData4 = MiddleData3 / MiddleData1;
 X = MiddleData4 - OFF;
  //Pressure = X*100/Get2_x(5)+C7*10;
 MiddleData1 = X * 100;
 MiddleData2 = pow2(5);
 MiddleData4 = coeff[C7] * 10;
 Pressure = MiddleData3 + MiddleData4;
 Temperature = 250 + dUT * coeff[C6] / pow2(16) - dUT / pow2(sensorParams[DD]);
static prog_int32_t BasicAltitude[PRESSURE_ARRAY_ELEMS] PROGMEM = {
-6983,-6201,-5413,-4620,-3820,-3015,-2203,-1385,-560, 270, //0.1m
 1108, 1953, 2805, 3664, 4224, 5403, 6284, 7172, 8068, 8972,
 9885, 10805,11734,12671,13617,14572,15537,16510,17494,18486,
 19489,20502,21526,22560,23605,24662,25730,26809,27901,29005,
 30121,31251,32394,33551,34721,35906,37106,38322,39553,40800,
 42060,43345,44644,45961,47296,48652,50027,51423,52841,54281,
 55744,57231,58742,60280,61844,63436,65056,66707,68390,70105,
 71854,73639,75461,77323,79226,81172,83164,85204,87294,89438};
long altitudeValue_P(int address){
// return the value of the altitude table
 return pgm_read_dword(&BasicAltitude[address]  );
long  HP03class::getAltitude(long pressure){  //pressure is 100 times what it should be
  int index;
  long AltitudeDifference,PressureDifference;
  long fraction;
  long alt;
  index = (MAX_PRESSURE - pressure/100) / PRESSURE_INC + 1;
  if (index >= PRESSURE_ARRAY_ELEMS)
       index = PRESSURE_ARRAY_ELEMS-1;
  AltitudeDifference =  altitudeValue_P(index) - altitudeValue_P(index-1);
  PressureDifference = pressure - ((MAX_PRESSURE - (index* PRESSURE_INC))*100);
  fraction = (AltitudeDifference *1000) - (PressureDifference  * AltitudeDifference)    ;
  alt = ((altitudeValue_P(index-1) * 10)  + (fraction/100))/10;
  if(distanceUnits == METERS)
      return alt;
      return  (long)(alt * 0.328084);
HP03class HP03 = HP03class();
maca_404
Thanks so much for the info.  I have put all the libraries etc in but am getting some errors when trying to compile.
In file included from C:\arduino-0012\hardware\cores\arduino/WProgram.h:4,
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:80: error: expected unqualified-id before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:80: error: expected `)' before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected `)' before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected identifier before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected `)' before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected ',' or '...' before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected initializer before ')' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:176: error: '__compar_fn_t' has not been declared
In file included from C:\arduino-0012\hardware\cores\arduino/WProgram.h:6,
I have confirmed that other programs are compiling ok so could this be something to do with the mod wire library you where talking about ?.  It is prb just something I have done wrong when copying it over but  it is strange as it does not seem to be referring to any of the new includes.
P.s  Im still very new at all this  ;)
mem
#4
Oct 13, 2008, 04:08 am Last Edit: Oct 13, 2008, 04:12 am by mem Reason: 1
hmm, to test I copied the files posted back onto my computer and they compile ok for me. Are you using the test sketch I posted? Are HP03.h and HP03.cpp copied to a directory called HP03 in the hardware/libraries directory? (Note there are three files named HP03.pde, HP03.H and the third needs to be called  HP03.cpp)
mikalhart
Mem, I *haven't* tried this code, but these are exactly the types of errors (stdlib.h:80) that people get when compiling old libraries with 0012.  My guess is that it works for you because you disabled or undefined those pesky "function-style" cast macros in wiring.h"?  If so, perhaps you'd care to share your method?
Mikal
mem
Thanks Mikal, I had forgotten that I had removed those pesky macros in my working copy of wiring,h.
#ifdef USE_PESKY_MACROS
#define int(x)     ((int)(x))
#define char(x)    ((char)(x))
#define long(x)    ((long)(x))
#define byte(x)    ((uint8_t)(x))
#define float(x)   ((float)(x))
#endif
mikalhart
Right-o!  maca, if you follow mem's example and add the #ifdef/#endif to your copy of wiring.h (effectively removing the five #defines in between), you will probably get happiness.
Mikal
mem
#8
Oct 13, 2008, 05:02 am Last Edit: Oct 13, 2008, 05:03 am by mem Reason: 1
Strange thing is that I just tried re-compiling the code I posted and even with the macros enabled it compiled ok.  hmm?
maca_404
Thanks for all your help so far guys, I have entered the info listed below and it has def reduced the amount of errors but still will not compile. Now it says
Any ideas on this one ?
Thanks
mikalhart
Yeah, also remove the #define of abs() in wiring.h.
Mikal
mem
Well spotted Mikal, I do have that commented out as well !
maca_404
Did you mean to remove this
#define abs(x) ((x)>0?(x):-(x))
When I remove that I get
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
down to 3 errors  :P
mem
#13
Oct 13, 2008, 05:39 am Last Edit: Oct 13, 2008, 05:40 am by mem Reason: 1
remove this:
#define round(x)     ((x)>=0?(long)((x)+0.5) (long)((x)-0.5))
(although it compiles ok on my system as is)
maca_404
#14
Oct 13, 2008, 05:59 am Last Edit: Oct 13, 2008, 06:43 am by maca_404 Reason: 1
duh forgot to bring xclear high,  Working perfectly now got lost of lovely data coming threw and looks like rain is on the way  :P.
Thanks so much for your help both of you have been a wealth of information. Also do you have any idea how accurate these things are in the real world  the temp and pressure are spot on but the altitude is out by about 450m or so, but I guess pressure i Probly not the best way to measure altitude.
