Topic: difficulties with web server (Read 2096 times) previous topic - next topic
zzyzxx
I'm having a bit of trouble getting the Yun web server running and need some help.
I have new Yun board and updated to openwrt-ar71xx-generic-yun-16M-squashfs-sysupgrade.bin with no issues.
Yun is on the correct network segment and the web panel can be reached with no problems. REST password is OFF.
I can upload sketches via serial and they work fine.
I can SSH to Yun with no issues.
However, the web server does not appear to be running. For example, http://local.arduino cannot reach the Yun ("server not found" error).
The SD card has arduino/www/index.html, but it cannot be reached, the error is "No such file or directory" using the Yun's address as: 192.168.2.72/sd, ("arduino.local/sd" returns "server not found").
The SD card is a 16 GB formatted Fat32.
Here is what the SD card looks like from SSH:
root@Arduino:/mnt/sda2/arduino/www# ls
index.html
Any help appreciated.
zzyzxx
#1
Jun 19, 2017, 01:00 am Last Edit: Jun 19, 2017, 01:05 am by zzyzxx
I started from scratch and reloaded the openwrt-ar71xx-generic-yun-16M-squashfs-sysupgrade.bin image. Yun is working fine now.
Except the http://arduino.local still comes back with "server not found".
ballscrewbob
local server has always tended to be a little hit and miss but via the YUN's IP seems to be the most reliable method.
Same thing in a different manner.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
zzyzxx
The arduino.local issue is easy to fix - once you know how!
You must install Bonjour for Windows, see here https://forum.arduino.cc/index.php?topic=189081.0
lga
#4
Oct 14, 2017, 10:45 pm Last Edit: Oct 14, 2017, 10:57 pm by lga
thank you, similar issue here and was able to resolve the same way. the config web page was very slow and strange looking. now works as expected.
remaining issue:
cannot just connect to the ip address but need to use the following url's:
http://192.168.10.112/cgi-bin/luci/;stok=cbe40abe7a81f7f9374542bbeaaad02a/webpanel/homepage
P.S.
had to upgrade from command line:
(command found here: https://www.arduino.cc/en/Tutorial/YunSysupgrade)
run-sysupgrade /mnt/sda1/openwrt-ar71xx-generic-yun-squashfs-sysupgrade.bin
(bin file previously copied to usb stick here mounted as /mnt/sda1)
AgroMeInc
It's not hit and miss or any mystery .
.local domains use multicast DNS. Either your network, operating system, or browser is not supporting mDNS very well:
https://en.m.wikipedia.org/wiki/Multicast_DNS
