Topic: Bras robot besoin aide  (Read 826 times) previous topic - next topic
yos27
salut a tous .
voila je suis sur le projet bras robot mais j'ai un probleme sur sa vitesse d'initialisation qui va trop vite .
Comment puis-je regler cette vitesse de demarrage, pour qu'il puisse prendre la valeur des potards a la bonne vitesse ? j'ai changer une partie du code pour fixer la vitesse avant d'attacher les servo mais ne veut rien savoir help me please .....
Code: [Select]
#include <VarSpeedServo.h>
VarSpeedServo servo1,servo2,servo3,servo4;
const int servo1pin = 12; //Servos
const int servo2pin = 11;
const int servo3pin = 10;
const int servo4pin = 9 ;
const int button1 = 2; //Buttons
const int button2 = 3;
int button1Presses = 0; //Button values
boolean button2Pressed = false;
const int pot1 = A0; //Potentimeters
const int pot2 = A1;
const int pot3 = A2;
const int pot4 = A3;
int pot1Val; //Potentimeter values
int pot2Val;
int pot3Val;
int pot4Val;
int pot1Angle;
int pot2Angle;
int pot3Angle;
int pot4Angle;
int servo1PosSaves[] = {1,1,1,1,1}; //position saves
int servo2PosSaves[] = {1,1,1,1,1};
int servo3PosSaves[] = {1,1,1,1,1};
int servo4PosSaves[] = {1,1,1,1,1};
  servo1.write(pot1Angle,10); // These will make the servos move to the mapped angles
  servo2.write(pot2Angle,10);
  servo3.write(pot3Angle,10);
  servo4.write(pot4Angle,10);
  servo1.attach(12,750,2130); // Set up everything and will run once; attach servos and define the pin modes
  servo2.attach(11,750,2130);
  servo3.attach(10);
  servo4.attach(9);
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  pot1Val = analogRead(pot1); // This will read the values from the potentimeters and store it...
  pot1Angle = map(pot1Val, 0, 1023, 0, 179); // ... and this will map the values from the potentiometers to values the servos can use and store it for later use
  pot2Val = analogRead(pot2);
  pot2Angle = map(pot2Val, 0, 1023, 0, 179);
  pot3Val = analogRead(pot3);
  pot3Angle = map(pot3Val, 0, 1023, 0, 179);
  pot4Val = analogRead(pot4);
  pot4Angle = map(pot3Val, 0, 1023, 0, 179);
  if(digitalRead(button1) == HIGH){ // This will check how many times button1 is pressed and save the positions to an array depending on how many times it is pressed; switch/case works like a if statement
    button1Presses++;
    switch(button1Presses){
      case 1:
        servo1PosSaves[0] = pot1Angle;
        servo2PosSaves[0] = pot2Angle;
        servo3PosSaves[0] = pot3Angle;
        servo4PosSaves[0] = pot4Angle;
        Serial.println("Pos 1 Saved");
      case 2:
         servo1PosSaves[1] = pot1Angle;
         servo2PosSaves[1] = pot2Angle;
         servo3PosSaves[1] = pot3Angle;
         servo4PosSaves[1] = pot4Angle;
         Serial.println("Pos 2 Saved");
      case 3:
         servo1PosSaves[2] = pot1Angle;
         servo2PosSaves[2] = pot2Angle;
         servo3PosSaves[2] = pot3Angle;
         servo4PosSaves[2] = pot4Angle;
         Serial.println("Pos 3 Saved");
       case 4:
         servo1PosSaves[3] = pot1Angle;
         servo2PosSaves[3] = pot2Angle;
         servo3PosSaves[3] = pot3Angle;
         servo4PosSaves[3] = pot4Angle;
         Serial.println("Pos 4 Saved");
       case 5:
         servo1PosSaves[4] = pot1Angle;
         servo2PosSaves[4] = pot2Angle;
         servo3PosSaves[4] = pot3Angle;
         servo4PosSaves[4] = pot4Angle;
         Serial.println("Pos 5 Saved");
  if(digitalRead(button2) == HIGH){ // Pretty self-explnatory here
    button2Pressed = true;
  if(button2Pressed){ // if the boolean button2Press is true, then the servos will run though all their saved positions
    for(int i = 0; i < 5; i++){
        servo1.write(servo1PosSaves[i],30);
        servo2.write(servo2PosSaves[i],30);
        servo3.write(servo3PosSaves[i],30);
        servo4.write(servo4PosSaves[i],30);
        Serial.println(" potentimeter Angles: ");
        Serial.println(servo1PosSaves[i]);
        Serial.println(servo2PosSaves[i]);
        Serial.println(servo3PosSaves[i]);
        Serial.println(servo4PosSaves[i]);
  delay(100);
trimarco232
#1
Jun 24, 2017, 01:29 pm Last Edit: Jun 24, 2017, 01:46 pm by trimarco232
Quote
Comment puis-je régler cette vitesse de démarrage, pour qu'il puisse prendre la valeur des potards a la bonne vitesse
Bonjour,
il faut tout simplement interdire de toucher aux potentiomètres pendant l'arrêt du robot
par ailleurs il faut sans doute que tu relises les définitions de
myServo.slowmove (newpos, speed);
