Topic: NHD[ch8208]0220D3Z[ch8208]NSW[ch8208]BBW - BAcklight ON/OFF (Read 518 times) previous topic - next topic
FPGA
Apr 20, 2010, 11:13 am Last Edit: Apr 20, 2010, 11:14 am by FPGA Reason: 1
Anyone has an example on howto put this backlight on writing something to it and then putting the backlight off??
my code works except the part where there must be text written to the LCD. This text is not correct.
Example:
Code: [Select]
#include <SoftwareSerial.h>
#define LCDrxPin 2
#define LCDtxPin 8
SoftwareSerial LCDSerial = SoftwareSerial(LCDrxPin,LCDtxPin);
 pinMode(LCDrxPin,INPUT);
 pinMode(LCDtxPin,OUTPUT);
 LCDSerial.begin(9600);
 delay(3000);
LCDSerial.print(254,BYTE); // Put LCD off by Backlight brightness
 LCDSerial.print(83,BYTE);
 LCDSerial.print(0,BYTE);
 delay(3000);
 delay(3000);
 LCDSerial.print(254,BYTE); // Put LCD on by Backlight brightness
 LCDSerial.print(8,BYTE);
 delay(3000);
  LCDSerial.print(254,BYTE); // Cursor Home Command
 LCDSerial.print(70,BYTE);
 delay(3000);
 LCDSerial.print("Test");
  LCDSerial.print(254,BYTE); // Clear Screen Command
 LCDSerial.print(81,BYTE);
 delay(3000);
Very much thank you
