Topic: Screen Keeps Freezing (Read 767 times) previous topic - next topic
shankulah60
Whenever I plug my Me Orion board into my computer the computer screen freezes leaving me with no control. At that point I have to restart the computer by physically pushing the power button. During the restart I unplug the USB cable, and once it has finished restarting the computer functions normally.  I reset the Me Orion board, but there is no change, it keeps freezing my computer screen.  Any ideas on why this might be happening.
shankulah60
I was wondering if anyone knew what this error meant, or how to fix it.
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.6.0_x64__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM3": Access is denied.
CrossRoads
On my laptop, COM3 is the USB hub for all the ports.
Is COM3 the port that opens on yours when you plug an Arduino in?
If you look at Tools:Port, does another COM port show up when your Arduino is plugged in?
shankulah60
#3
Jun 28, 2017, 06:29 pm Last Edit: Jun 28, 2017, 06:35 pm by shankulah60
Yes, COM3 is the port that opens when I connect my Arduino. No other ports are listed under Tools:Port
CrossRoads
If you look in Device Manager, is it listed there as well?
No ! over it?
shankulah60
It is listed under the ports section in the device manager.
spycatcher2k
Have you restarted your computer?
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
shankulah60
#7
Jun 28, 2017, 07:42 pm Last Edit: Jun 28, 2017, 07:51 pm by shankulah60
I restart my computer after the computer starts acting up.(Which happens every time I plug the USB cable into the computer). It makes no difference.
CrossRoads
Perhaps the Orion is drawing too much USB power and the computer is not handling it well?
My Lenovo Thinkpad senses USB overcurrent and shuts the port down and reports a power surge error. Have to restart the laptop to clear it. Has also happened when external 5V supply backdrives the USB supply line, so I have an FTDI extender cable now with the 5V line set up to be disconnected, and have started putting in back-feed prevention diodes in designs as well.
shankulah60
Thanks, that partially fixed the problem.
I am now getting an error:
         Using Port                              : COM3
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xed
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xed
I have no clue what this means!
CrossRoads
Got a link to the Orion board?
Is it 328P equipped?
Is it loaded with a bootloader?
What board type are you selecting when attempting to download?
shankulah60
http://learn.makeblock.com/makeblock-orion/
It is supposed to be a Arduino Uno duplicate. Previously it has worked flawlessly, today it has started to act up for no apparent reason.
CrossRoads
#12
Jun 28, 2017, 09:29 pm Last Edit: Jun 28, 2017, 09:29 pm by CrossRoads
Are you selecting Uno as the board type?
With this speed
I would suspect not. I'm pretty sure Uno use 115200 for serial download.
Schematic also shows a CH340G for the USB interface, do you have the drivers downloaded for that?
shankulah60
That Fixed it!
Thank you so much for all your help throughout the day!
