Topic: Using on-board RTT or RTC to wake Due from backup mode (Read 1 time) previous topic - next topic
selim
I'm trying to get my Due to wake up from the SAM3X on-board backup mode using it's integrated RTT or RTC.
To wake up from backup mode, the board needs an interrupt from the RTC or RTT. However, I can't seem to find an installable Atmel RTC or RTT library that I can use their example code with. I have tried to use MarkusLange's RTCDue library to do this, but it doesn't seem to throw an interrupt and did not wake from backup mode when I tested it.
For reference, here is the code I used:
Code: [Select]
 rtc.begin();
  rtc.setTime(23, 59, 56);
  rtc.setDate(22, 11, 2016);
  rtc.setAlarmDate(23, 11);
  rtc.attachAlarm(sayHi);
pmc_enable_backupmode();
void sayHi() {
Serial.println("Hello, I'm alive!");
When I removed pmc_enable_backupmode() the code ran as it should, saying "Hello, I'm alive!" after 4 seconds.
I'm on macOS so I can't really use ASF and get their example code, as well. Any help, code or links would be greatly appreciated!
ard_newbie
There are several ways to enter and exit from backup mode. See this thread reply #1:
https://forum.arduino.cc/index.php?topic=469943.0
selim
