Topic: Problem running IDE v18 (Read 544 times) previous topic - next topic
alpierce
I am trying to get a Duemilanove board running on a Macbook Pro OSX 10.6.3. I have the FTDI drivers installed but when I launch the IDE I get the following dialog box:
Cannot Launch Java Application
Uncaught exception in main method: java.lang.UnsatisfiedLinkError: /Library/Java/Extensions/librxtxSerial.jnilib:  no suitable image found.  Did find:  /Library/Java/Extensions/librxtxSerial.jnilib: mach-o, but wrong architecture
Only option is Quit.
I went through several blogs and forums and it seemed it might be a JAVA 1.6 problem, so I installed 1.5 and have tried both the 32 and 64 bit versions. I checked the Rosetta option for the IDE ( no 32 bit mode option) using get info. Same result. Has anyone else seen this or have any ideas?
Thanks
Al
