Topic: Replacing records in sd file (Read 343 times) previous topic - next topic
orbitcoms
I have an application that I need to store fixed length records into file on SD card and then transmit the files in batches to another application. The other application is not always available so I need to be able to handle sending some of the records from the file and later sending more. Once all files are sent then I can re-write the file back to zero bytes and start again.
Is there a way to get the number of lines of text in a file and also to set some sort of pointer where to get next records from? or better, to advance to the required line of text?
PaulS
No. You can get the number of bytes in the file. Divide that by the number of bytes in a record to get the number of records. The file has no idea how many bytes are in a record, so it can't tell you how many records there are.
You can use seek() to go to a specific location to start reading.
