Topic: Newbie Question (Read 789 times) previous topic - next topic
Darwin74
I am creating an LED bouncing ball effect with 10 LED's set up as an array, bouncing from 9 - 0 - 8 - 0 ...... and want to use a simple method of coding the last highest LED (-1) as the maximum 'bounce point' and then returning to 0 and so on. I am unsure of how to most effectively use the minus sign.
I did have success using the following code to get the LED to bounce from LED 10 back to 0 and then to 9:
void changeLED() {
 // turn off all LED's
 for (int x=0; x<10; x++) {
   digitalWrite(ledPin[x], LOW);
 // turn on the current LED
 digitalWrite(ledPin[currentLED], HIGH);
 // increment by the direction value
 currentLED += direction;
 if (currentLED == 0) {direction = 1;}
 if (currentLED == currentLED1) {direction = -1;}
with int currentLED = 9
      int currentLED1 = 8
However, trying to use this principle any futher does not seem to work.
Any help would be appreciated.
drhex
#1
Jun 29, 2010, 08:11 am Last Edit: Jun 29, 2010, 08:14 am by drhex Reason: 1
well, if the limits are 0 and currentLED1 ("maxLED" might be less confusing), then let currentLED start somewhere between those extremes or you might "bounce" outside the allowed range.
Darwin74
Thanks for that, makes sense.
I will give it a shot and report back.
Thanks again for your help
