Topic: Why can't just delete sd card files on pc ? (Read 489 times) previous topic - next topic
samalgerie25
Apareantly I have a stupid question!  why can't just delete sd card files on pc instead of format it? especaily  I   tried it and the card kept working well!
MorganS
If it works, why is there a problem?
Who told you (what web page) that you had to format SD cards to delete files?
"The problem is in the code you didn't post."
QuantumComputing73
You should be able to do so, If its not letting you it may be because the small tab on the left of the SD card is in the "lock" position, meaning you cant remove files.
Think Outside the Box...Unless the box has an Arduino in it.
