Topic: io.h folder/files (Read 602 times) previous topic - next topic
ccliche
Trying to flash a modified parameter file for a 3D printer with the RADDS DUE based system.   Using Repetier and/or Marlin.  Get the same result.  Compiling is terminated because there is no "io.h" file/folder.  Both Repetier and Marlin through Arduino IDE have a "fastio.h".  Problem doesn't exist with the RAMPS/MEGA 2560 combination.
Not being able to reflash the DUE makes it useless as a one shot deal.
Any suggestions?
Thanks
Carl
westfw
Io.h is an avr-only thing.  Due normal io may be fast enough that you don't need a fast io, but it sounds like you'll need to find a version of the marlin/whatever firmware that was designed for due.
