system
1
I am struggleing writing a code to control a valve output controlled by a button input with an emergency stop also written in.!!
The Format of the test is as followed
Button Pressed
System Primed - which involved 10 x 2sec of output causing the valve to open with 2 sec rest intervals inbetwwen.
this is then followed by 5 mins of valve being open
close valve
END - wait for button to be pressed to comense test again....
with an emergency stop built in to end the process straight away!!!
ANY HELP WOULD BE VERY MUCH APRIECIATED!! ;D ;D
L JOHNSTON
system
2
OK, OK. Stop the screaming already.
What you want to do is simple enough. Read the state of two buttons - the start and the stop buttons. If the stop button is not pushed, do something.
What to do depends on what time it is, and the last thing done.
If you are struggling to write the code, that suggests you have some code that is not exactly right.
Post that code, and explain what is wrong, and when the homework is due, and we'll help you with it.
Quietly, please.
