Topic: Client/Server Questions Using Ethernet Shield (Read 547 times) previous topic - next topic
Mavromatis
Aug 03, 2010, 07:46 am Last Edit: Aug 03, 2010, 07:48 am by Mavromatis Reason: 1
What are you guys using as the best Ethernet Library for W5100 based ethernet shields?
There is Ethernet2, Updated Client (http://code.rancidbacon.com/LearningAboutArduinoEthernet) and a bunch of other fixes posted on this forum.   I'm using v18 so I'm not sure what has been built in vs tweaks I need to still make?
My problem now is that I have a server which works very good.  Problem is that my client only works once.    What I'm trying to accomplish is that I get hit via HTTP get command with some data.
I occasionally need to make an outgoing HTTP request (client) every hour to notify a server I'm still listening.   The problem starts when I create the client and use it once.  It works... after that it always fails.
Code looks something like this:
Code: [Select]
    // setup the Ehternet library to talk to the Wiznet board
    Ethernet.begin(mac, ip);
    // subscribe to transport notifictions
    subscribe(false);
void loop(){  // main loop
  server.begin(); // based on forum post
  if (isSubscribed){
     if(currentMillis - previousMillis > interval) {
       currentTime += 1;
     if (currentTime >= (subscriptionTimeout - 300)){
       currentTime = 0;
       // send a renew subscription message
       subscribe(true);
 } // isSubscribed
  // server code
  Client webclient = server.available();
 if (webclient) {
   while (webclient.connected()) {
     if (webclient.available()) {
       // process incoming web request
     } // end of available
   } // end of while loop
  } // end of webclient
void subscribe(boolean renew)
 Client subClient(subIP, 1400);
 if (subClient.connect()) {
   // send something to server...
    delay(1);
    Serial.println("sub sent");
    subClient.flush();
    subClient.stop();
     while(subClient.status() != 0) { // ADDED Aug 2 (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1235991468)
            delay(5);
    Serial.println("disconnecting.");
   if (debug) {
     Serial.println("fail");
    // if we fail, resubscribe!
    isSubscribed = false;
    subscribe(false);
What is happening is that the first subscribe works perfect... every one after fails... any idea why?
