Topic: Running Loop once and leaving LED lit until button released (Read 2929 times) previous topic - next topic
midwesta
Grumpy_Mike
Do i need to use a latch function?
What latch function?
If you want the LEDs to stop on for the whole time a button is pressed just hold your code in a while loop.
Code: [Select]
while(digitalRead(pin) == pressed) { } // where the variable pressed is the logic level you get when the button is held down.
