Topic: Uploading problem in arduino pro mini 3.3v clone called betemcu !!! (Read 855 times) previous topic - next topic
CHEGGARI
Hello guys,
I bougth an arduino pro mini 3.3v 8MHz and when I try to upload a code it says "uploading..." and it still in that situation, i ve been reading some solutions which say that the reset button should be pressed and did it with no result.
I am really stack with this for now, i need help please!!!
ieee488
Hello guys,
I have a few Arduino Pro Mini 5V 16MHz purchased from 3 different eBay sellers,
and I have no problems uploading using a FTDI USB-TTL adapter.
I don't need to push the Reset button.
I use the DTR, TX, RX, VCC, and GND pins for uploading code.
pert
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch  > Upload
  • After the process fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
double_alpha
Please help me.. i have the same issue . Here's the error message i get
Arduino: 1.8.3 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Archiving built core (caching) in: C:\Users\Daniel\AppData\Local\Temp\arduino_cache_579525\core\core_arduino_avr_diecimila_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 2586 bytes (8%) of program storage space. Maximum is 30720 bytes.
Global variables use 186 bytes (9%) of dynamic memory, leaving 1862 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\Daniel\AppData\Local\Temp\arduino_build_544176/motor_test.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x86
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
DrAzzy
Are you using a Pro Mini clone (like the OP) or a Duemillanove/Decimillia clone? Selecting a board that doesn't match the board you're uploading to is one of many things that can lead to the sync error. It sounds like you don't have the same problem as the OP - as they describe it getting hung on uploading, while you get a sync error, so you should not have posted your question in the same thread.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
