Topic: DS1307 day of the week (Read 3271 times) previous topic - next topic
opale7000
Hello All
How to I go about obtaining day of the week from a DS1307 RTC?
This is partial code
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
  while (!Serial) ; // wait for serial
  delay(200);
  Serial.println("DS1307RTC Read Test");
  Serial.println("-------------------");
  tmElements_t tm;
  if (RTC.read(tm)) {
    Serial.print("Ok, Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    Serial.write(':');
    Serial.print(tm.Wday);
    Serial.println();
I figured that
Would give me something other than 0 ?
pert
Are the other time values as you expect?
It looks like weekday 0 is an error code. The weekdays are 1 indexed.
opale7000
All other values are good!
Ok, Time = 13:18:08, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:09, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:10, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:11, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:12, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:13, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:14, Date (D/M/Y) = 19/7/2017:0
Ok, Time = 13:18:15, Date (D/M/Y) = 19/7/2017:0
The value at the end of line is 0 for DayOfWeek
opale7000
I have used to followed code to set the DS1307RTC. Perhaps it should be revised to include DOW?
#include <Wire.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
  bool parse=false;
  bool config=false;
  // get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
    parse = true;
    // and configure the RTC with this info
    if (RTC.write(tm)) {
      config = true;
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(200);
  if (parse && config) {
    Serial.print("DS1307 configured Time=");
    Serial.print(__TIME__);
    Serial.print(", Date=");
    Serial.println(__DATE__);
  } else if (parse) {
    Serial.println("DS1307 Communication Error :-{");
    Serial.println("Please check your circuitry");
    Serial.print("Could not parse info from the compiler, Time=\"");
    Serial.print("\", Date=\"");
    Serial.print(__DATE__);
    Serial.println("\"");
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
cattledog
#4
Jul 19, 2017, 07:42 pm Last Edit: Jul 19, 2017, 07:45 pm by cattledog
It does for me when I run your sketch.
The DS1307 library reads the storage register (0x03) in the rtc chip to get the weekday. What is the setting in that register? Here's some test code to read and write the dow register.
// DS1307 I2C NVRAM test
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
#define startRegister 0x00
#define endRegister 0x07
  Wire.begin();
  Serial.print("Register");
  Serial.print("\t");
  Serial.println("Bit Values");
  Serial.println();
  //write dow register use value 0-6
 // writeNVRAM(0x03,B00000100);//day4
  for (int a = startRegister; a <= endRegister; a++)
    byte b=readNVRAM(a);
    Serial.print("0X");
    if(a<16)
      Serial.print("0");
    Serial.print(a, HEX);
    Serial.print("\t");
    Serial.print("\t");
    for (int i = 7; i >= 0; i-- )
      Serial.print((b >> i) & 0X01);//shift and select first bit, no speed advantage
    Serial.println();
void writeNVRAM(byte location, byte data)
// writes data to DS1307 NVRAM location
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.write(location);
  Wire.write(data);
  Wire.endTransmission();
byte readNVRAM(byte location)//// reads data from DS1307 NVRAM location
  Wire.requestFrom(DS1307_I2C_ADDRESS, 1);//only 1 byte, does not need wire.available
  return Wire.read();
void loop(){
opale7000
I ran your test code and get this
Register Bit Values
0X00 00100101
0X01 01000111
0X02 00010011
0X03 00000000
0X04 00011001
0X05 00000111
0X06 00010111
0X07 00000011
cattledog
OK, now uncomment the write piece of the code and set the day you want.
aarg
You're already using the Time library. If you set the RTC time using the library, it will automatically update the DOW register for you.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
opale7000
Well using the cattledog script solved my Problem. Thanks so much for your help  :)
aarg
The library already includes name strings that you can use.
