Topic: The number servowrite() to stop continous servo motor is changed !!! (Read 606 times) previous topic - next topic
Muhalimachrus
I have successfully modified the regular servo motor into a continuous servo motor (by following the tutorial on the internet, I removed the potentiometer and I replaced it with 2k2 ohm resistor).
I need a continous servo motor because it is easier to control with ON-OFF using EMG muscle sensor. Instead of a potentiometer, I use a piezoelectric disc as feedback to stop the motor at a certain position.
At first my experiment was successful, the modified continous servo motor successfully calibrated to stop by entering the number on servowrite (). But after the motor moves for a while, and the motor starts to warm up, suddenly the motor can not stop.
After I review with the code for motor calibration then I find the number to stop the motor on servowrite () changed (from the original 101 to 97). I suspect this is a result of the motor being hot and the resistor getting hot, so the resistor value is changed.
There is a solution to avoid this (without having to buy an original continous servo motor)?
Thank you very much.
AWOL
Quote
I would normally expect there to be two resistors, forming a potential divider.
edgemoron
Kind of like this:
Muhalimachrus
Totally correct!
But my problem is the number to stop servo is changed!
>>>First time
  myservo.write(101); //first trial this number make the servo stoped
>>>After several time
  myservo.write(97); //after several time I need to change the number to stop servo, Number 101 is no longer able to stop the servo (the servo still moving in slow speed).
Muhalimachrus
