Topic: Controlling RGB Leds (Read 1 time) previous topic - next topic
adyrn001
I wanted to use nearly 100 RGB Leds to light at once (Like RED)and after some delay all shoulb be in different colour(like Green). I Want to use arduino. How can i do that, is there any solution to that.
INTP
Easiest with smart LEDs, buy a strip of WS2812B LEDs.
septillion
Do all leds need to be the same color or all different? That makes a HUGE difference ;)
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
ieee488
It appear he wants them to be able change colors.
The example he gives is from red to green.
septillion
Yeah, but you can read that two ways ;)
All change to the new different color but all the same.
OR all change to a individual different color.
For the first using NeoPixels is a bit overkill :)
ieee488
Other than RGB LEDs are there others that lets him change colors on the fly?
septillion
No, but read it again ;) He does not make clear of all those leds need to change to the same new color or from all being one single color to being all a different color.
All NeoPixels are RGB leds. Not all RGB leds are NeoPixels :)
If all those 100 (RGB) leds just need to go from red to green all at the same time NeoPixels can be used but are wayyyyyyy overkill. Normal RGB leds with simple transistors in front is way simpler and a heck of a lot cheaper.
ieee488
To me they are synonymous as when people use the brand name Kleenex to mean facial tissue.
septillion
To me they are in NO way synonymous. NoePixels and WS2801, WS2811, WS2812B, LPD8806 or TM1809 are.
But a normal RGB led
and NeoPixel
[img  width=500]https://cdn-shop.adafruit.com/970x728/2659-03.jpg[/img]
are not.
Like I said, a NeoPixel is a RGB led, a RGB led does not need to be a NeoPixel ;)
ieee488
#9
Jul 23, 2017, 10:45 pm Last Edit: Jul 23, 2017, 10:46 pm by ieee488
To me, a RGB LED is a generic RGB with the controller whereas the NeoPixel is a brand name.
septillion
Then you have a weird view ;) To me (and many many others) a RGB led is a led and tells NOTHING about the driver. That there are leds with build in driver and we tend to call them by the brand name NeoPixel just is a subset
NeoPixel ∈ RGB led
RGB led ∉ NeoPixel
ieee488
NeoPixel ∈ RGB led
RGB led ∉ NeoPixel
The ones I buy on eBay don't have brand names.
To me, when people are asking about them here, I translate RGB LED as being shorthand for RGB LED with controller especially when they are talking about them as on a LED strip.
If the OP doesn't mean that, then perhaps he will return and set me straight.
Grumpy_Mike
#12
Jul 23, 2017, 11:34 pm Last Edit: Jul 23, 2017, 11:37 pm by Grumpy_Mike
Quote
Then you are missing something big.
Their are four major types:-
1) Four connections, one positive and one for each of the grounds for R,G and B. Normally these are 12V and are controlled by a PWM signal driving a FET in each colour line. This is how you use them https://learn.adafruit.com/rgb-led-strips/usage. What ever is the colour all the LEDs on that strip have the same colour.
2) Three connections 12V - Every three LEDs have full independent colour control.
3) Three connections 5V - power ground and data, of the WS2812 type sometimes called Neopixels. Each LED has full independent colour control.
4) Four connection 5V - power ground data clock, sometimes called dot star. Each LED has full independent colour control.
https://learn.adafruit.com/adafruit-dotstar-leds/overview?view=all
septillion
As Grumpy_Mike also says, I would drop that idea and ask what the person has / want to. Option 1 is still the most sold strip in China supermarkets :)
ieee488
#14
Jul 24, 2017, 12:14 am Last Edit: Jul 24, 2017, 12:25 am by ieee488
I have never been to a supermarket in China so I don't know what they sell.
Perhaps you can point out the four types on eBay.
As I said, that's where I buy mine.
