I don't know if the Wemos board can handle 2A. I would not want to take the risk. You might burn your house down. Presumably you want to use the Wemos' micro usb socket to connect the charger to the strip. It would be safer to cut off the usb plug and solder on a barrel plug. Then use a barrel socket, with separate wires going to the strip and the 5V pin on the Wemos (plus common grounds, of course).
