Topic: error: 'String' does not name a type In function (Read 19502 times) previous topic - next topic
magma
Compiling a sketch I obtain this error
error: 'String' does not name a type In function 'void leggiSeriale()':
At global scope:
In function 'void acquisisciip()':
Bad error line: -20
Can you help me?
I must post the code?
I created two .pde file and I import them in two tab... I don't know if this is correct.
http://www.open-electronics.org
PaulS
Can you help me?
Yes, we can.
Well, you said you wanted help.
mpeuser
You most likely forgot to
#include <String.h>
magma
Thank you.
I tried to add
#include <String.h>
but doesn't work.
I upload the code here:
http://www.tmpfolder.com/download.php?dir=../upload/6c92469c2448/&filename=ws2300_3.rar
The code is not complete. There are two sketch:
ws2300_3.pde  is the sketch to read the wether station WS2300 / WS2350 / WS2305 WS2308 and it works.
With the serial interface you can ask the WS data.
The other sketch ethernet.pde must be modified. I want to publish WS data on line. When the code is finished, I will publish the work.
Thank you.
IIf someone wants to cooperate, I will be very happy
Coding Badly
magma
In the file ethernet.pde I write
#include <Ethernet.h>
#include <WString.h>
#include <EEPROM.h>
#include <NewSoftSerial.h>
#include <String.h>
I must include this header in ws2300.pde also?
probably just a configuration problem ... but I am a beginner and do not find a tutorial on how to solve these problems ... Sorry for the lack
mpeuser
The new String (version 0.9 I think) IS the old WString (or TextString).... You might have issues in using both of them. There is no need for this.
magma
With or without
#include <String.h>
the compiling doesn't work...
How do I configure the IDE to work with multiple files?
PaulS
You might try this:
#include <WString.h>                // include the String library
magma
These are my include
#include <EEPROM.h>
PaulS
In the Sketch + Import Library menu, is the String library importable?
magma
Ok I solved.
I import the .h in ws2300.pde and not in ethernet.pde...
I did not understand why but it works well now.
Thanks to all.
ull
Do you care to share your current version of this sketch?
magma
Yes of course. You can help me...
[code]
//  Copyright (C) 2010 Landoni Boris
//  http://technolando.blogspot.com/
//  http://www.futurashop.it
//  http://www.elettronicain.it/
//  WS2300 is free software: you can redistribute it and/or
//  modify it under the terms of the GNU Lesser General Public License
//  as published by the Free Software Foundation, either version 3 of
//  the License, or (at your option) any later version.
//  WS2300 is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//  GNU Lesser General Public License for more details.
NewSoftSerial mySerial(2, 3);   //NewSoftSerial mySerial(rx,tx);
const int ledPin = 6; // the pin that the LED is attached to
const int rts = 4;
const int dtr = 5;
void leggiSeriale() {
 int incomingByteSer;      // a variable to read incoming serial data into
 // see if there's incoming serial data:
 if (Serial.available() > 0) {
   // read the oldest byte in the serial buffer:
   incomingByteSer = Serial.read();
   // if it's a capital H (ASCII 72), turn on the LED:
   Serial.flush();
  if (incomingByteSer == 'R') {
     Serial.println("RESET");
     delay(2000);
     digitalWrite(rts, HIGH);
     digitalWrite(dtr, LOW);
     delay(2000);
     digitalWrite(rts, LOW);
     digitalWrite(dtr, HIGH);
     mySerial.print(byte(06));
   if (incomingByteSer == 'o') {
     String data=getTime();
     Serial.print("ora ");
     Serial.println(data);
   if (incomingByteSer == 'd') {
     String data=getDay();
     Serial.print("giorno ");
   if (incomingByteSer == 't') {
     String data=getTempIn();
     Serial.print("temperatura interna ");
   if (incomingByteSer == 'T') {
     String data=getTempOut();
     Serial.print("temperatura esterna ");
   if (incomingByteSer == 'h') {
     String data=getHumIn();
     Serial.print("umidità interna ");
   if (incomingByteSer == 'H') {
     String data=getHumOut();
     Serial.print("umidità esterna ");
   if (incomingByteSer == 'p') {
     String data=getPress();
     Serial.print("pressione ");
   if (incomingByteSer == 'w') {
     String data=getWind(0);
     Serial.print("wind speed ");
   if (incomingByteSer == 'W') {
     String data=getWind(1);
     Serial.print("wind dir ");
   if (incomingByteSer == 'r') {
     String data=getRain1();
     Serial.print("rain 1 ");
   // if it's an L (ASCII 76) turn off the LED:
   if (incomingByteSer == 'L') {
     digitalWrite(ledPin, LOW);
// Function to clear a string
void clearStr (char* str) {
  int len = strlen(str);
  for (int c = 0; c < len; c++) {
     str[c] = 0;
String Leggi (int mem[]) {
   String inString = String(35);
   int incomingByte;      // a variable to read incoming serial data into
   int time=0;
 /*  Serial.print("memoria ");
   for (int tmp=0; tmp<5; tmp++){
     Serial.print(mem[tmp],HEX);
     Serial.print(" ");
   Serial.println();
   incomingByte=0;
    while ((incomingByte!=2) && (time<20)){
         time++;
         delay(20);
         /*while ((mySerial.available() == 0) && (time<100)){
            delay(20);
            time++;
         time=0;
           if (mySerial.available() > 0) {
             incomingByte = mySerial.read();
             inString.append(incomingByte);
    //         Serial.print("RICEVUTO ");
    //         Serial.println(incomingByte);
    clearStr(inString);
    mySerial.flush();
    if (time==100){
    //     Serial.print("errore reset ");
         return("0");
       mySerial.print(byte(mem[tmp]));
       //Serial.print("-> ");
       //Serial.println((mem[tmp]),HEX);
        delay(30);
        time++;
       if (time==100){
      //   Serial.print("errore ");
      //   Serial.println(tmp);
         return("0");
         break;
       time=0;
       /*if (mySerial.available() > 0) {
         Serial.println(incomingByte,HEX);
      //delay(200);
          while (mySerial.available() > 0) {
               delay(20);
               //inString.append(incomingByte,HEX);
         //      Serial.print("<- ");
         //      Serial.println(incomingByte,HEX);
               //(incomingByte & B11110000);
               if (tmp<4){
                 //Serial.print("nibble ");
                 //Serial.println(((incomingByte & B11110000)/B10000),HEX);    //isolo il nibble più significativo e lo faccio slittare
                 //Serial.print("tmp ");
                 //Serial.print(tmp);
                 if (tmp!=((incomingByte & B11110000)/B10000)){
          //           Serial.print("confronto ERRATO ");
                     return("0");
                     break;
                 //else
                 //    Serial.print("confronto OK ");
               if (tmp==4){
                 if (incomingByte<=0xF){
                   inString.append(0);
 //      Serial.print("stringa ricevuta ");
 //      Serial.println(inString);
       return(inString);
String getTime(){
     String dataStr=0;
     Serial.print("leggo ora ");
     int my_array[] = {0x82,0x8A,0x82,0x82,0xDA};
     dataStr= elabTime(my_array);
     return(dataStr);
String getDay(){
     String dataStr=0;
     Serial.print("leggo giorno ");
     int my_array[] = {0x82,0x8A,0x8E,0xAE,0xEE};
     dataStr= elabDay(my_array);
     return(dataStr);
String getTempIn(){
     String dataStr=0;
     Serial.print("leggo temperatura interna ");
     int my_array[] = {0x82,0x8E,0x92,0x9A,0xFA};
     dataStr= elabTemp(my_array);
     return(dataStr);
String getTempOut(){
     String dataStr=0;
     Serial.print("leggo temperatura esterna ");
     int my_array[] = {0x82,0x8E,0x9E,0x8E,0xFA};
     return(dataStr);
String getHumIn(){
     String dataStr=0;
     Serial.print("leggo umidità interna ");
     int my_array[] = {0x82,0x8E,0xBE,0xAE,0xDA};
     dataStr= elabHum(my_array);
     return(dataStr);
String getHumOut(){
     String dataStr=0;
     Serial.print("leggo umidità esterna ");
     int my_array[] = {0x82,0x92,0x86,0xA6,0xDA};
     return(dataStr);
String getPress(){
     String dataStr=0;
     Serial.print("leggo pressione ");
     int my_array[] = {0x82,0x96,0xBA,0x8A,0xD6};
     dataStr= elabPress(my_array);
     return(dataStr);
String getWind(int dato){
     String dataStr=0;
     Serial.print("leggo wind ");
     int my_array[] = {0x82,0x96,0x8A,0x9E,0xF2};
     dataStr= elabWind(my_array,dato);
     return(dataStr);
String getRain1(){
     String dataStr=0;
     Serial.print("leggo pioggia 1h ");
     int my_array[] = {0x82,0x92,0xAE,0x92,0xDA};
     dataStr= elabRain1(my_array);
     return(dataStr);
String elabTime(int my_array[]){
           String dataStr = String(5);
           //float dataFloat=0;
       for (int ritenta=0; ritenta<3; ritenta++){
       //    Serial.print("ritenta ");
       //    Serial.println(ritenta);
           inString=Leggi(my_array);
           //Serial.print("stringa ricevuta2 ");
           //Serial.println(inString);
           if (inString.length()>5){
               //data= inString.substring(4,6);  //estraggo i decimali della temperatura
               dataStr.append(inString.substring(6,8));  //estraggo i decimali della temperatura
               dataStr.append(":");
               dataStr.append(inString.substring(4,6));  //estraggo i decimali della temperatura
               dataStr.append(inString.substring(2,4));  //estraggo le decine e unità della temperatura
               //Serial.print("tempin ricevuta   ");
               //Serial.println(dataStr);
               //tempin=data;
               //dataFloat = (atof(dataStr));
               //Serial.print("tempin float   ");
               //Serial.println(dataFloat);
               break
