Topic: Error compiling for board NodeMCU 1.0 (ESP-12E Module) (Read 15354 times) previous topic - next topic
milkjug7
I have looked up this error and the most common answer is that I need to flash my NodeMCU ESP8266. I thought I've already done that and the only issue with the problem being that my ESP8266 might not be flashed is that this error only shows when I change a certain line of code.
As of right now, I'm messing around with code that allows me to turn an LED on or off through the web. What I'm trying to do is add a blink to it, I have two tabs one of which has the blinking code(Blink.h) and the other has the main code (AP_Simple_12e_WITH_BLINK). The error shows up when I use #include later in the code. If I remove the line saying "#include <Blink.h>;" (Under the comment // Match the Request) I don't get the error and it compiles with no issue.
I know that you can't use two loops in one program so I'm kinda out of ideas on what to do. The goto doesn't allow you to jump to another Tab, and the only reason I used another tab was to make the code neat and readable. I understand that the goto is bad to use but since I can't use another loop function and me being so new to this I need some help.
The reason there is a digitalWrite right above the #include was for me to see if it was the placement of
 the code around the #include that was causing the issue. (from my understanding, it isnt)
Code: [Select]
#include <ESP8266WiFi.h>
const char* ssid = "Pool Wifi";
const char* password = "arduino";
int ledPin = 13; // GPIO13
WiFiServer server(80);
  delay(10);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("/LED=ON") != -1)  {
    digitalWrite(ledPin, HIGH);
    value = HIGH;
  if (request.indexOf("/LED=OFF") != -1)  {
    value = LOW;
  if (request.indexOf("/LED=BLINK") != -1)  {
    #include <Blink.h>;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
  // Return the response
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.print("Led pin is now: ");
  if(value == HIGH) {
    client.print("On");
    client.print("Off");
  client.println("<br><br>");
  client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
  client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a><br />");
  client.println("<a href=\"/LED=BLINK\"\"><button>Blink </button></a>");
  client.println("</html>");
  delay(.5);
  Serial.println("Client disonnected");
  Serial.println("");
Code: [Select]
Blinker:
  goto Blinker;
This is the error message I get, again only when I use the #include (probably where I'm not supposed to). I Can include the verbose version of the error if needed.
compilation terminated.
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\milkj\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
PaulS
Quote
You could, or I could post the last few lines of the answer.
PieterP
Including a file doesn't just insert the code there.
Preprocessor directives don't have a semicolon at the end of the line.
Don't use goto.
Do you realize that your program (if it was written correctly) would go into an infinite loop once a client requests "/LED=BLINK"?
Pieter
antruong
1:Running the command 'appdata' from Run window.
2:Select and doubleclick to open "Local" folder.
3:Delete Arduino15
4:Visit the link and follow the instructions :
-https://www.instructables.com/id/Quick-Start-to-Nodemcu-ESP8266-on-Arduino-IDE/
(don't change any thing)
5:install driver
-https://sparks.gogo.co.nz/ch340.html
-https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
6:enjoy. :smiley-cool:
