Topic: 9 DOF Razor help (Read 1 time) previous topic - next topic
mrwelcam
Hi, I'm a newbie and am a little stuck. I have just purchased a 9 DOF Razor IMU (SEN-09623) and a 3.3v FDTI breakout  (DEV-08772) which I'm powering via usb.
I'm trying to convert the gyro reading to angles but am doing something wrong. If i turn the board 90 degrees my conversion will only give me readings of around 30 degrees.
Here is my algorithm
sensitivity = 0.83 // as per datasheet
zeroLevel = 1.23 // as per datasheet
degPerSecond = (gyroXvalue * 3.3/1024 - zeroLevel)/sensitivity
angle = degPerSecond * elapsedTime + previousAngle
I'm using the values of 3.3 because its a 3.3V power supply and 1024 because its a 10 bit ADC
What am i doing wrong? Do i have the sensitivity and zero level correct? I would like post the datasheet, but not allowed.
Any guidance would be really appreciated.
Cheers
andrew0
Now you've made one post you'll be allowed to post a link to the data sheet.
Andrew
mrwelcam
The 9DOF razor
http://www.sparkfun.com/commerce/product_info.php?products_id=9623
has two gyro's. A LY530AL (single-axis gyro) and a LPR530AL (dual-axis gyro).
Here are the links to the datasheets
LY530AL:
http://www.sparkfun.com/datasheets/Sensors/IMU/LY530ALH.pdf
LPR530AL:
http://www.sparkfun.com/datasheets/Sensors/IMU/lpr530al.pdf
AWOL
What is your analogue reference voltage?
mrwelcam
Not too sure. How do i find out the analogue reference voltage? It's powered via USB if thats any help.
Sorry, im new to this
onedaime
hi, i'd purchased the same type of 9 dof as you are and connected it to my pc via Ftdi basic . Could u give me the code in adruino software, to display the value of gyroscope, accelerometer and magnetometer? thank you an advance.
