Topic: How many Decibels nRF24L01 uses? (Read 984 times) previous topic - next topic
duinoWorld
I am working on a project which an nRF24L01 (Receiver) will need to receive from another nRF (Transmitter), to determine the transmitter's distance/range(In meter if possible), dB (if possible), to locate the transmitter.
I've seen that if nRF24L01 wants to get the dB, it requires RPD.
Is it correct?
Quote
bool RF24::testRPD(void)
  return (read_register(RPD) & 1);
If its correct, how to add it to my Receiver's coding?
jremington
#1
Aug 16, 2017, 05:55 am Last Edit: Aug 16, 2017, 05:56 am by jremington
Quote
This idea comes up at least once a week in this forum, and it is not possible.
Received signal strength depends on many factors, most of them more important than the distance between transmitter and receiver .
duinoWorld
But i just want to calculate the distance between them. Do you have any ideas?
jremington
Quote
A measuring tape, laser distance sensor, etc. (anything but radio signal strength).
Robin2
Why?
If you tell us that we can probably give a more useful answer.
I have had a pair of nRF24s (the low power ones with the PCB antenna) working at 110 metres distance outdoors.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
duinoWorld
I am trying to use my NRF (Receiver) to detect where the Transmitter would be. Even when it is moved to another places. I just want to know any way to detect the exact place, or calculate the distance through any formula. But NOT using measuring tape or laser distance sensor. Just using the NRF24L01
Robin2
That won't work.
You could put a GPS on each device and use the nRF24 to exchange the position data from the GPS.
...R
MaHa76
only theoretical
You could try to Count the timer for Signal- send ping - receive answer and compare it with time fpor processing...
Signal will take 300m per millis... so you Need to make your System realy stable and solid...
(sorry for my poor english)
Robin2
Whandall
299.792.458 m/s means 300m per micro second, or 18.7m per cycle (with 16MHz).
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
DaveEvans
Um, no.  300 m/s (or 343 m/s or whatever) is equivalent to:
3x10^2 m/s
...times 10^-6 s/us = 3x10^-4 m/us
...times 10^3 mm/m = 3x10^-1 mm/us
or, simply, 0.3 mm/us
jremington
#11
Aug 18, 2017, 03:16 am Last Edit: Aug 18, 2017, 03:19 am by jremington
Quote
Um, no.  300 m/s
is very roughly the velocity of sound in air, not light (the topic of this thread and correctly discussed by Whandall).
DaveEvans
el_supremo
Even if you could accurately measure the distance to the transmitter, you still don't know the direction to its new location.
Pete
Don't send me technical questions via Private Message.
MaHa76
#14
Aug 18, 2017, 07:08 am Last Edit: Aug 18, 2017, 07:09 am by MaHa76
@Whandall: You are right - there Aare 3 Digits missing... 300 per micros...
So maybe it would be possible to add an Sonar- Module to each Note - start a Ping and Count time till it recieves on other Note...
Start Event could be shared between Notes via nrf24.
For Location more Notes are Need to compare different running times...
