Topic: Connecting and working with Mega +WiFi R3 ATmega2560+ESP8266 (32Mb memory) (Read 18449 times) previous topic - next topic
Juraj
Juraj
sorry AT 2.0 is new. I didn't see until now
I tested the esp8266 AT 2.0 firmware, which is esp32 AT firmware compiled on esp8266 RTOS SDK IDF framework.
It communicates over pins 13 RX and 15 TX so it can be used only with modules with this pins accessible. On esp8266 dev boards, you can't communicate with this AT firmware from PC over the on board USB chip, because that is traditionally wired to io 0 and 3.
and the commands set is older then in 1.x esp8266 AT firmware (non-OS SDK 2 and 3)
I didn't test SSL
kxondus
"the Serial3 dip switched connect Serial of esp8266 with Serial3 of Mega."  Not sure I understand.  Individually these code examples work, but not together.
Trying to run this code on the Mega;;
// Basic serial communication with ESP8266
// Uses serial monitor for communication with ESP8266
// When a command is entered in to the serial monitor on the computer
// the Arduino will relay it to the ESP8266
#include <SoftwareSerial.h>
SoftwareSerial ESPserial(2, 3); // RX | TX
    Serial.begin(115200);     // communication with the host computer
    //while (!Serial)   { ; }
    // Start the software serial for communication with the ESP8266
    ESPserial.begin(115200);
    Serial.println("");
    Serial.println("Remember to to set Both NL & CR in the serial monitor.");
    Serial.println("Ready");
    Serial.println("");
    // listen for communication from the ESP8266 and then write it to the serial monitor
    if ( ESPserial.available() )   {  Serial.write( ESPserial.read() );  }
    // listen for user input and send it to the ESP8266
    if ( Serial.available() )       {  ESPserial.write( Serial.read() );  }
and trying to run something like this on the ESP8266;;
    HTTP over TLS (HTTPS) example sketch
    This example demonstrates how to use
    WiFiClientSecure class to access HTTPS API.
    We fetch and display the status of
    esp8266/Arduino project continuous integration
    build.
    Limitations:
      only RSA certificates
      no support of Perfect Forward Secrecy (PFS)
      TLSv1.2 is supported since version 2.4.0-rc1
    Created by Ivan Grokhotkov, 2015.
    This example is in public domain.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#ifndef STASSID
#define STASSID "ZZZZZZZ"
#define STAPSK  "XXXXXXX"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
const char* host = "api.github.com";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char fingerprint[] PROGMEM = "5F F1 60 31 09 04 3E F2 90 D2 B0 8A 50 38 04 E8 37 9F BC 76";
  Serial.print("connecting to ");
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // Use WiFiClientSecure class to create TLS connection
  WiFiClientSecure client;
  Serial.println(host);
  Serial.printf("Using fingerprint '%s'\n", fingerprint);
  client.setFingerprint(fingerprint);
  if (!client.connect(host, httpsPort)) {
    Serial.println("connection failed");
    return;
  String url = "/repos/esp8266/Arduino/commits/master/status";
  Serial.print("requesting URL: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: BuildFailureDetectorESP8266\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("request sent");
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("headers received");
  if (line.startsWith("{\"state\":\"success\"")) {
    Serial.println("esp8266/Arduino CI successfull!");
    Serial.println("esp8266/Arduino CI has failed");
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println(line);
  Serial.println("closing connection");
Did you got it?. I'm trying to understand how it works. I've changed "ESPSerial" to Serial3, because as Juraj said, it's yet wired.
