Topic: AI-Thinker A6 GSM: Receiving but not sending (Read 2322 times) previous topic - next topic
rund1me
Dear Forum!
I want to be using an ESP-12 and the AI-Thinker A6 GSM like stavros did (https://gitlab.com/stavros/A6-ESP8266-breakout/) and iam using his library (https://github.com/skorokithakis/A6lib) and or a simple serial redirector.
I have a problem that the RX is working fine and 115200 baud seems to be sending from the module, also i receive +CIEV: service,  1\n+CIEV: roam, 0\n+CREG: 1. But iam not able to send to the A6 from the serial, i immediately receive the same answer i have sent, but not OK. When using the library i cant get it to connect via AT as well.
I would really appreciate some help.
Here is the code i use:
#include <SoftwareSerial.h>
#define DEBUG
#include <A6lib.h>
#define SERIAL_A6_BAUD 115200
//#define SERIAL_A6_BAUD 9600
#define SERIAL_ESP_BAUD 115200
//#define SERIAL_ESP_BAUD 9600
#define GPIO_A6_RX 14
#define GPIO_A6_TX 13
#define GPIO_A6_POWER 4
//#define USE_LIB
//#define LOOP_AT
#ifndef USE_LIB
char buffer[1024];
char end_c[2];
SoftwareSerial A6board (GPIO_A6_RX, GPIO_A6_TX);
#endif
#ifdef USE_LIB
A6lib A6l(GPIO_A6_TX, GPIO_A6_RX);
#endif
  Serial.begin(SERIAL_ESP_BAUD);
  while (!Serial) { }
  log("Serial set to ");
  log(SERIAL_ESP_BAUD);
  logln(" baud");
#ifdef USE_LIB
  logln("Starting power cycle");
  A6l.powerCycle(GPIO_A6_POWER);
  logln("Wait until ready");
  int ret = A6l.blockUntilReady(SERIAL_A6_BAUD);
  log("Seems ready:");
  logln(ret);
#else
  logln("Enabling A6 power switch");
  pinMode(GPIO_A6_POWER, OUTPUT);
  logln("Enabling A6 rx");
  pinMode(GPIO_A6_RX, INPUT);
  logln("Enabling A6 tx");
  pinMode(GPIO_A6_TX, OUTPUT);
  log("Starting A6 serial: ");
  log(SERIAL_A6_BAUD);
  logln(" baud");
  A6board.begin(SERIAL_A6_BAUD);
  logln("Switch A6 ON");
  digitalWrite(GPIO_A6_POWER, HIGH);
  logln("READY:");
  end_c[0] = 0x1a;
  end_c[1] = '\0';
#endif
#ifdef LOOP_AT
bool somethingReceived = false;
#endif
#ifdef USE_LIB
    while (A6l.A6conn->available() > 0) {
        logln("RECEIVED:");
        Serial.write(A6l.A6conn->read());
    while (Serial.available() > 0) {
        logln("SEND:");
        A6l.A6conn->write(Serial.read());
#else
#ifdef LOOP_AT
  if(somethingReceived){
      A6board.write("AT\n");
      logln("SEND: AT");
      delay(200);
#else
  if (Serial.available()) {
    String hh = Serial.readStringUntil('\n');
    hh.toCharArray(buffer, hh.length() + 1);
    if (hh.indexOf("END") == 0) {
      A6board.write(end_c);
      logln("SEND: END");
      A6board.write(buffer);
      A6board.write('\n');
      log("SEND: ");
      logln(buffer);
#endif
  if (A6board.available()) {
    log("RECEIVED: ");
    logln(A6board.readStringUntil('\n'));
#ifdef LOOP_AT
    somethingReceived = true;
#endif
#endif
#ifdef LOOP_AT
  delay(200);
#else
  delay(10);
#endif
rund1me
I dont know about the library yet but sending only a \n doesnt seem sufficient enough.
The problem was that my board always sent back the command i sent without any error code or other indication.
Sending 0x0D (Carriage Return) and 0x0A (Line feed or Newline) seemed to do the trick:
A6board.write(0x0D);
A6board.write(0x0A);
If this issue persist in the library i will probably also change it there and push a fix.
AyrtonNP
I have the same problem, could you solve it?
