Topic: 4 DIFFERENT LOAD CELLS WITH 4 HX711?? (Read 2192 times) previous topic - next topic
nickpilot1
Aug 27, 2017, 03:38 pm Last Edit: Aug 27, 2017, 06:22 pm by nickpilot1
Hello. I need your help. I have an arduino uno board,4 x hx711 and 4 load cells... And I want to weigh with 4 scales each separately, and each scales to activate a servo. That is, the first scale when the weight is less than 53g (0-53g)  the first servo make 180 degrees else 0 degrees. The second scale when weighing is from 53g to 63g make the second servo 180 degrees otherwise 0. The third when the weigh is 63g to 73g make a sevo 180 degrees and the fourth when the weigh is Greater than 73g servo make a 180 degrees.
I can do it? You can tell me the code??
This is my code. I do not know how to put second load cell...
Code: [Select]
#include "HX711.h"
#define calibration_factor -5990.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define DOUT  A3
#define CLK  A2
HX711 scale(DOUT, CLK);
#include "Servo.h"
Servo Servosmall;
int pos = 0;
int pos2=180;
int small=53;
  Serial.println("HX711 scale demo");
  scale.set_scale(-5990); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
  Serial.println("Readings:");
  Servosmall.attach(9);
  Serial.print("Reading: ");
  Serial.print(scale.get_units(20), 1); //scale.get_units() returns a float
  Serial.print(" g "); //You can change this to kg but you'll need to refactor the calibration_factor
if (scale.get_units() > small){
    Servosmall.write(pos);
  else  {
    Servosmall.write(pos2);
PaulS
Quote
Explain why you need to. Is the object being weighed going to weigh significantly more or less when you weigh it again?
nickpilot1
I'm trying to make this construction:
www.youtube.com/watch?v=WUJE1dMNC-M&list=FLAK5JM4t49XlUzAsXmdFnNg
I want to sort the eggs by weight class.
Did you help?
PaulS
Why do you have two threads going on the same topic?
patduino
#4
Aug 28, 2017, 06:18 pm Last Edit: Aug 28, 2017, 06:18 pm by patduino
I saw your YouTube link. Are you making one of those? It looks like the eggs might crack when they bang into each other.
Why not make a single weight measurement with a a single load cell and categorize the eggs based on the single measurement?
There are 10 types of people in the world, those who understand binary, and those that don't.
nickpilot1
finally with a little effort I did it. it works perfectly.
Νow I want help.
I want with two buttons to change the price of small
a button for up (+1gr) and a button for down(-1gr)
how to do this;
This is my code
Code: [Select]
#include "HX711.h"
#define calibration_factor = -5990.0
HX711 scale(3,2);
HX711 scale2(5,4);
HX711 scale3(6,7);
HX711 scale4(9,8);
#include "Servo.h"
Servo Servosmall;
Servo Servomedium;
Servo Servolarge;
Servo Servoxlarge;
int pos = 0;
int pos2=180;
float small= 53;
float medium=63;
float large=73;
float xlarge=83;
  scale2.set_scale(-5990); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale2.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
  scale3.set_scale(-5990); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale3.tare(); //Assuming there is no weight on the scale at start up, reset the scale to
  scale4.set_scale(-5990); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale4.tare(); //Assuming there is no weight on the scale at start up, reset the scale to
  Servosmall.attach(13);
  Servomedium.attach(12);
  Servolarge.attach(11);
  Servoxlarge.attach(10);
  Serial.print("scale 1: ");
  Serial.print(scale.get_units(1), 2); //παρε μοναδες (1) με (2) δικαδικα ψιφια
  Serial.print(" g \t|"); //You can change this to kg but you'll need to refactor the calibration_factor
  Serial.print("scale 2: ");
  Serial.print(scale2.get_units(1), 2); //scale.get_units() returns a float
  Serial.print(" g\t| "); //You can change this to kg but you'll need to refactor the calibration_factor
  Serial.print("scale 3: ");
  Serial.print(scale3.get_units(1), 2); //scale.get_units() returns a float
  Serial.print("scale 4: ");
  Serial.print(scale4.get_units(1), 2); //scale.get_units() returns a float
    Servosmall.write(pos);}
  else  {
    Servosmall.write(pos2);}
if (scale2.get_units() < small && scale2.get_units() > medium){
    Servomedium.write(pos);
  else  {
    Servomedium.write(pos2);
if (scale3.get_units() < medium && scale3.get_units() > large){
    Servolarge.write(pos);
  else  {
    Servolarge.write(pos2);
  if (scale4.get_units() < large && scale4.get_units() > xlarge){
    Servoxlarge.write(pos);
  else  {
    Servoxlarge.write(pos2);
    if(Serial.available())
    char temp = Serial.read();
    if(temp == '+' || temp == 'a')
      small += 1;
    else if(temp == '-' || temp == 'z')
      small -= 1;
