Hello, I uploaded to my Arduino mega 2560 a program that connects to ultra sonic HC-SR04 rangefinder
sensor and debugs on the serial monitor the range it detects.
I have run this on a dry run without the sensor yet but in either case my arduino reads 0 as it should be but the delay between each read is way more than it should be, it suppose to delay it by roughly 50 ms but in practice, it delays it like 1 second.
There is the code I used:
Juraj:
it spends time in function called by the function op1()
sterretje:
And your full code is ??
Also be aware that if you print a lot, the software output buffer used by e.g. Serial.print will fill up and block your code once it's full.
FYI: At 9600 baud, transmission of one character takes roughly 1 ms.
The rest of the code isn't the problem, I tried to delete the op1(); lines and it turned out to work fine.
Is there anything that I can do in order to make the calculations faster or make it work faster?
sterretje:
You have an unknown function distance() in there; for all I know you can have a delay in there. I know it's not likely but we can't be sure.
We also don't know how often you call your op1() and you might be filling the serial buffer (as indicated).
Maybe use of the newping library? No experience with it but as far as I know it can be used non-blocking.
Alright so there is the only time I call op1() and distance:
void initialization(){
for(int i = 0;i<=180;i++){
pos.write(i);
// op1();
range = dist;
sterretje:
That depends on what is printed at which speed; and I know that you know that
Of course, if we didn't know what was being printed, we couldn't make an assertion like that. But we do know what's being printed - a single floating point value followed by a CRLF sequence, each pass through that function.
In the initial post didn't the OP say the sensor wasn't connected yet?
No sensor presumably means no pulse. So isn't pulsein() going to time out every time? And by a strange coincidence the default timeout is exactly the time he's complaining about (which is what I thought AWOL was trying to tell him before things went off in all sorts of other directions).
