Topic: Arduino UNO WiFi with external antenna (Read 2727 times) previous topic - next topic
aelektronikk
Hi, I am new here so just bear with me....
I connected an external antenna to my UNO WiFi board, and I cannot
find information anywhere about if I have to make changes so that the
external antenna will be operative.
It looks like the on-board antenna is still active....
Anyone?
aelektronikk
Thanks.
I've already seen it, and it does not explain everything..
I will remove the onboard antenna and see what happens...
Juraj
#3
Aug 29, 2017, 12:41 pm Last Edit: Nov 24, 2017, 02:29 pm by Juraj
Do you have the schema?
Uno WiFi Dev Ed schema
aelektronikk
#4
Aug 30, 2017, 11:04 am Last Edit: Aug 30, 2017, 11:19 am by aelektronikk
Hi.
Yes, I have the schematics, but not the board-layout.
I removed the internal antenna(X3), and added a link to the CX1 connector.
The modification works great.
Thank you Juraj for helping out. :)
Juraj
#5
Aug 30, 2017, 12:37 pm Last Edit: Nov 24, 2017, 02:31 pm by Juraj
nice job
can I add it with your photos to Uno WiFi unofficial documentation?
Eagle files
aelektronikk
rabathome
The photo's don't explain what you did. could there be some markers in the photo's
Juraj
explanation is in link in replay #1 and look at the schema in #3
rabathome
#9
Jan 14, 2018, 03:44 pm Last Edit: Jan 14, 2018, 04:27 pm by rabathome
I modified the board and it works fine. Thanks for the info.
djmattc
I also need to install an external antenna but it's not clear what I need to do and the link in reply #1 no longer works.
Juraj
this is for the first Uno WiFi. the Developer Edition.
https://github.com/jandrassy/UnoWiFiDevEdSerial1/wiki/Hardware
