Here is the updated file with comments & installation path added in the header. I hope this will help to get the low consumption figure on mkrfox1200.
Please take also into account the great benefits of a setup boost 3.3V circuit, which makes batttery life about 10 times longer. My reference is the NCP1402, and its implementation by Sparkfun.
Copyright (c) 2015 Arduino LLC. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
// Philgeek on www.philoc.fr
// Edited on 2018/03/17 thanks to question / my post on Arduino forum mkrfox1200/lowest consumption issue
// I just hope it can help but I cannot commit ;-)
// This file has been updated as I looked for the lowest consumption on mkrfox1200
// The modification below is tagged with "phg" embedded in the comment
// Only one line had to be placed as comment ...
// Notes :
// The path on my configuration is .arduino15/packages/arduino/hardware/samd/1..6.16/cores/arduino/wiring.c
// Notes / Prerequisites
// All unused components, and especially sigfox and usb must have been reset by your application before entering deep sleep
// And Arduino Low Power library must be in its 1.2.0 version, at least in my configuration
// Lastly check any pin configuration, be careful with pullups and leds ... but you did that already
// And at he end of the day, you should get around 50 mA, as I've got by myself ... because the data sheet figures & the mkrfox1200 schematics are done that way.
#include "Arduino.h"
#ifdef __cplusplus
extern "C" {
#endif
* System Core Clock is at 1MHz (8MHz/8) at Reset.
* It is switched to 48MHz in the Reset Handler (startup.c)
uint32_t SystemCoreClock=1000000ul ;
void calibrateADC()
volatile uint32_t valeur = 0;
for(int i = 0; i < 5; ++i)
ADC->SWTRIG.bit.START = 1;
while( ADC->INTFLAG.bit.RESRDY == 0 || ADC->STATUS.bit.SYNCBUSY == 1 )
// Waiting for a complete conversion and complete synchronization
valeur += ADC->RESULT.bit.RESULT;
valeur = valeur/5;
* Arduino Zero board initialization
* Good to know:
* - At reset, ResetHandler did the system clock configuration. Core is running at 48MHz.
* - Watchdog is disabled by default, unless someone plays with NVM User page
* - During reset, all PORT lines are configured as inputs with input buffers, output buffers and pull disabled.
void init( void )
// Set Systick to 1ms interval, common to all Cortex-M variants
if ( SysTick_Config( SystemCoreClock / 1000 ) )
// Capture error
while ( 1 ) ;
NVIC_SetPriority (SysTick_IRQn, (1 << __NVIC_PRIO_BITS) - 2); /* set Priority for Systick Interrupt (2nd lowest) */
// Clock PORT for Digital I/O
// PM->APBBMASK.reg |= PM_APBBMASK_PORT ;
// // Clock EIC for I/O interrupts
// PM->APBAMASK.reg |= PM_APBAMASK_EIC ;
// Clock SERCOM for Serial
PM->APBCMASK.reg |= PM_APBCMASK_SERCOM0 | PM_APBCMASK_SERCOM1 | PM_APBCMASK_SERCOM2 | PM_APBCMASK_SERCOM3 | PM_APBCMASK_SERCOM4 | PM_APBCMASK_SERCOM5 ;
// Clock TC/TCC for Pulse and Analog
PM->APBCMASK.reg |= PM_APBCMASK_TCC0 | PM_APBCMASK_TCC1 | PM_APBCMASK_TCC2 | PM_APBCMASK_TC3 | PM_APBCMASK_TC4 | PM_APBCMASK_TC5 ;
// Clock ADC/DAC for Analog
PM->APBCMASK.reg |= PM_APBCMASK_ADC | PM_APBCMASK_DAC ;
// Setup all pins (digital and analog) in INPUT mode (default is nothing)
for (uint32_t ul = 0 ; ul < NUM_DIGITAL_PINS ; ul++ )
// modification - PHG - 2017-09-13 : line below suppressed in order to get lower consumption in standby /deep sleep mode '<50uA)
// pinMode( ul, INPUT ) ;
// Initialize Analog Controller
// Setting clock
while(GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY);
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID( GCM_ADC ) | // Generic Clock ADC
GCLK_CLKCTRL_GEN_GCLK0 | // Generic Clock Generator 0 is source
GCLK_CLKCTRL_CLKEN ;
while( ADC->STATUS.bit.SYNCBUSY == 1 ); // Wait for synchronization of registers between the clock domains
ADC->CTRLB.reg = ADC_CTRLB_PRESCALER_DIV512 | // Divide Clock by 512.
ADC_CTRLB_RESSEL_10BIT; // 10 bits resolution as default
ADC->SAMPCTRL.reg = 0x3f; // Set max Sampling Time Length
ADC->INPUTCTRL.reg = ADC_INPUTCTRL_MUXNEG_GND; // No Negative input (Internal Ground)
// Averaging (see datasheet table in AVGCTRL register description)
ADC->AVGCTRL.reg = ADC_AVGCTRL_SAMPLENUM_1 | // 1 sample only (no oversampling nor averaging)
ADC_AVGCTRL_ADJRES(0x0ul); // Adjusting result by 0
analogReference( AR_DEFAULT ) ; // Analog Reference is AREF pin (3.3v)
// Initialize DAC
// Setting clock
while ( GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY );
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID( GCM_DAC ) | // Generic Clock ADC
while ( DAC->STATUS.bit.SYNCBUSY == 1 ); // Wait for synchronization of registers between the clock domains
DAC->CTRLB.reg = DAC_CTRLB_REFSEL_AVCC | // Using the 3.3V reference
DAC_CTRLB_EOEN ; // External Output Enable (Vout)
#ifdef __cplusplus
#endif
