Topic: Force Sensitive Resistor OverLoad (Read 716 times) previous topic - next topic
CMAZE
I've got just a simple question. What happens when I overload FSR. Let's say that it's got force sensitive range between 100g and 10 000g. What would happen if I'd create pressure about 100kg? I see that resistance is decreasing with bigger pressure. Will there be almost 0 ohm resistance? If so, can this FSR survive this overload? Has somebody test that?
Thank you for any answer.
wvmarle
If you apply a large enough pressure you will destroy it. No doubt about that. Do mind that pressure = force / area. Just force (directly related to weight) has little meaning, making your question far from as simple as you think it is.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
