Topic: Stray 302 Error? (Read 667 times) previous topic - next topic
ArshiaKO
 I copied this code on the internet and it gives me a 302 stray error. Here is the code:
Code: [Select]
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#include <Keypad.h>
#include<EEPROM.h>
int relPin;
int state=0;
byte  COD[10];
byte  AUX[10];
int k=0;
String accessCode="*123456#";
String codpairing="*654321#";
//NFC
#define RST_PIN   9
#define SS_PIN 10
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
#define NEW_UID {0xDE, 0xAD, 0xBE, 0xEF}
MFRC522::MIFARE_Key key;
//LCD
LiquidCrystal_I2C  lcd(0x27,16,2);
//KEYPAD
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {2,3,4,5}; //Rows 0 to 3
byte colPins[numCols]= {A0,7,8,9}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
  pinMode(A0,OUTPUT);
  digitalWrite(A0,HIGH);
  pinMode(A3,OUTPUT);
  digitalWrite(A3,HIGH);
  pinMode(A1,OUTPUT);
  digitalWrite(A1,HIGH);
  pinMode(A2,OUTPUT);
  digitalWrite(A2,LOW);
  //NFC
  Serial.begin(9600);  // Initialize serial communications with the PC
  while (!Serial);  // Do nothing if no serial port is opened
  SPI.begin(); // Init SPI bus
 mfrc522.PCD_Init();     // Init MFRC522 card
 for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
lcd.begin();
lcd.backlight();
lcd.setCursor(0,0);
lcd.clear();
lcd.print( "BLOCKED" );
void  readNFC(){   // This function will read the code stored on
 for (byte i =0; i<(mfrc522.uid.size); i++) {  // the  UID
   COD[i]=mfrc522.uid.uidByte[i];
 Serial.print("COD");
 Serial.print(COD[0]);
 Serial.print(COD[1]);
 Serial.print(COD[2]);
 Serial.print(COD[3]);
void pairNFC(){
 Serial.println("COD in pair");
  long  r=0;
  int c=0;
  for(int i=1;i<=EEPROM.read(0);i++){                       //The UID cannot be stored on
switch(i%4){                                                     // one variable, it was needed to be
      case 1 :{AUX[0]=EEPROM.read(i); break;}     // split
      case 2 :{AUX[1]=EEPROM.read(i); break;}
      case 3 :{AUX[2]=EEPROM.read(i); break;}
      case 0 :{AUX[3]=EEPROM.read(i); break;}
if((i)%4==0)
   {Serial.println(r);
    if( AUX[0]==COD[0] && AUX[1]==COD[1] && AUX[2]==COD[2] && AUX[3]==COD[3] ){                                      //Verify if the code is in EEPROM
         lcd.clear();
         lcd.setCursor(0,0);
         lcd.print("CODE ALREADY IN");
         lcd.setCursor(0,1);
         lcd.print("SYSTEM");
      delay(2000);
          c=1;
      break;}
if(c==0){int aux2=EEPROM.read(0);
             Serial.println("CODE PAIRED");
         EEPROM.write(aux2+1,COD[0]);  //Writing code in EEPROM
         EEPROM.write(aux2+2,COD[1]);
         EEPROM.write(aux2+3,COD[2]);
         EEPROM.write(aux2+4,COD[3]);
         aux2=aux2+4; // Position for a new code
         Serial.println("aux2");
         Serial.println(aux2);
         EEPROM.write(0,0);
         EEPROM.write(0,aux2);
         lcd.clear();
         lcd.setCursor(0,0);
         lcd.print("CODE PAIRED");
         delay(2000);}
boolean validationNFC(){
  boolean c=false;
  for(int i=1;i<=EEPROM.read(0);i++){   //Read the EEPROM
      switch(i%4){
if((i)%4==0)
    if( AUX[0]==COD[0] && AUX[1]==COD[1] && AUX[2]==COD[2] &&                AUX[3]==COD[3])
      c=true; //Verify if the code is in EEPROM and make flag=true;
  return c;
int compareCODE(String a)    //We type a code on keypad and this will be compared
{ //with the accessCode;
 if(a.equals(accessCode))
return 1;
 else if(a.equals(codpairing)) return 2;
 else return 0;
String takeCode(char x) //Will display on the LCD the code typed
{ char vec[10];
 vec[0]=x;
 lcd.setCursor(0,0);
 lcd.clear();
 lcd.print('X');
 for(int i=1;i<8;i++)
    {vec[i]=myKeypad.waitForKey(); //Waits for 8 keys to be pressed and after that
     lcd.print('X');} //is taking the decision
 vec[8]=NULL;
 String str(vec);
 return str;
  switch(state){
  case 0: {
    mfrc522.PCD_Init();
    if (  mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial() ){
    readNFC(); //It will read the card and it will search for UID in its
    if(validationNFC()) //memory
       { state=1;
        lcd.clear();
        lcd.setCursor(0,0);
lcd.print( "VALID NFC CODE" ); //The door will be opened
        return;
    else{
         lcd.clear();
         lcd.setCursor(0,0);
         lcd.print( "INVALID NFC CODE" ) //If the code was wrongblocked
         lcd.setCursor(0,0);
         lcd.clear();
         return;
char c=myKeypad.getKey();
  if(c != NO_KEY){
String codcurent=takeCode(c);
int A=compareCODE(codcurent);
  if(A==0){                                //A is a variable that stores the current code
   lcd.clear();
   lcd.print("INVALID CODE");
   delay(2000);
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.print("BLOCKED");
   return;
  if(A==1){
lcd.setCursor(0,0);
     lcd.clear();
   lcd.print( "VALID CODE " );
delay(2000);
   state = 1;
   Return;
  if(A==2); {
state=2;
         lcd.clear();
         lcd.setCursor(0,0);
        lcd.print( " Pairing..." );
      delay(2000);
    return;}
 case 1:{
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print( "UNLOCKED" );
    digitalWrite(A3,LOW);
    digitalWrite(A1,LOW); //The red LED will be off
    digitalWrite(A2,HIGH); //The green LED will be on
    tone(6,3000,5010); //The buzzer will make a sound
    delay(5000); //After 5 seconds the system will be blocked
    state=0;
    lcd.setCursor(0,0);
    lcd.clear();
return;
  case 2:{
   mfrc522.PCD_Init();
      readNFC();
      pairNFC();
      state=0;
      delay(2000);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print( "BLOCKED" );   }
pert
This is caused by some garbage character you picked up from the website you copied it from. If you copy the code you posted here back into your sketch the problem will be solved because the forum strips those characters.
