Topic: Step motor DC 4-9V/500mA stucks (Read 667 times) previous topic - next topic
mizario
Hello everyone
I´m trying to run a step motor with my Arduino Mega and EasyDriver V44 A3967.
I did my best but I can´t make it turn.
Can you guys please give me hand ?
Motor specs:
2 phases
4 wires
step angle 18 degrees
Driving Voltage: DC 4-9V/500mA
to test it and identify the coils I measured the resistency among the wires and it´s 20 Ohm.
I also plugged a Led and when I turn the shaft by hand it blinks.
so I assume the motor is working.
To drive it Im using V44 A3967 (Easy Driver).
to power the motor I´m using 4 AA 1.5 v batteries.
Total 6 v connected to EasyDriver power in and the Easydriver red led turns on.
When I run my code the motor does like one step and gets suck.
If I unplug the motor I can turn the shaft by hand but once it connected in my driver running the code I can´t turn the shaft.
Is my 6v enough to power this motor ?
Here is my simple code:
// Easy driver pins declaration
int pin_step =3;
int pin_dir =2;
int steps_motor =20;   //I assume 20 steps for one revolution 360/ 18deg because motor step angle=18
  // Define pins as output
  pinMode(pin_step, OUTPUT);
  pinMode(pin_dir, OUTPUT);
  digitalWrite(pin_step, LOW);
  digitalWrite(pin_dir, HIGH);   //define direction
  for (int p=0 ; p < steps_motor; p++)
   digitalWrite(pin_step, HIGH);
   delay (5);
   delay (5);
Here is the motor link:
https://pt.aliexpress.com/item/DC-4-9V-Drive-Stepper-Motor-Screw-With-Nut-Slider-2-Phase-4-Wire/32699526798.html?spm=a2g03.search0104.3.2.SKxtFH&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10173_10326_10084_10083_10080_10307_10082_10081_10110_10137_10111_10060_10112_10113_10155_10114_10154_143_10056_10055_10054_10312_10313_10059_10314_100031_10099_10078_10338_10079_10103_10073_10102_440_10052_10053_10142_10107_10050_10051,searchweb201603_20,ppcSwitch_5&btsid=830c0b87-500e-4c05-9ddf-2418152f504c&algo_expid=097165e4-47b5-4a39-ba8a-2ed59e0d6644-0&algo_pvid=097165e4-47b5-4a39-ba8a-2ed59e0d6644
Thanks in advance
Mizar
Rio de Janeiro, Brazil
PaulS
Quote
Yes. The current that the 4 batteries output may be nowhere near enough, though. In general, stepper motors are not powered by batteries.
MarkT
Steppers don't have a voltage rating, so that's a 0.5A stepper of unknown winding resistance.  Perhaps
you should measure the winding resistance.  Then we can figure out the minimum usable supply voltage.
