Topic: Frequency generator code for Si5351 adafruit (Read 5958 times) previous topic - next topic
OH2BTG
Here is RF generator code for adafruit Si5351 and Si5351 chip.
It is capable to make frequency output from 1MHz to 150MHz with various step from 100Hz to 10MHz.
It can be used as local oscillator for amateur radio. Signal output is square wave so there is lot of harmonics. They must be taken a count if this generator is used for transmitter.
It uses rotary coder and small standard LCD display.
Many parts of SW is borrowed from various other sketches, but frequency calculation part is studied from  si5351 AN619 and checked using Clock Builder Pro from Silicon Labs
Im not aware of bugs. Igot code ready last night so it is not extensively tested.
Best Regard:
OH2BTG
Code: [Select]
//v.0.0.5 09.09.2017 Frequency generator 1...150MHz with 100Hz steps.  OH2BTG
#include <Wire.h>
#include <Adafruit_SI5351.h>
#include <LiquidCrystal.h>
#include <rotary.h>
#include <si5351.h>
Adafruit_SI5351 clockgen = Adafruit_SI5351();
#define ENCODER_A    3                      // Encoder pin A
#define ENCODER_B    2                      // Encoder pin B
#define ENCODER_BTN  4 // Encoder c button
Rotary r = Rotary(ENCODER_A, ENCODER_B);
volatile uint32_t vfo = 14578750000 ;// initial frequency in Hz Put your favourite frequency here
uint32_t pllFreq; // si5351 internal vco frequency
uint32_t radix = 12500; //start step size 12.5kHz
uint32_t si5351multiCount; // Multicounter
uint32_t si5351multi_int;  // Multicounter integer
uint32_t si5351nomi; // Multicounter nominator
uint32_t si5351denomi = 1000000; //Multicounter denominator one million
uint32_t si5351divider; // VCO output divider integer part
boolean changed_f = 1;
String tbfo = "";
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //  LCD: RS,E,D4,D5,D6,D7 Erska
/* Displays the frequency             */
void count_frequency()
  uint16_t f, g;
 lcd.clear();
  lcd.setCursor(3,0);
  f = vfo / 1000000;   //variable is now vfo instead of 'frequency' vfo esim 145787500
  si5351divider = 900000000/vfo; // vfo divider integer
  pllFreq = si5351divider * vfo; // counts pllFrequency
  si5351multiCount = pllFreq / 25; // feedback divider
  si5351multi_int = pllFreq / 25000000; // feedback divider integer
  si5351nomi = si5351multiCount % 1000000;  // feedback divider integer
  si5351denomi = 1000000; // feedback divider fraktion
  Serial.print(" vfo ");
  Serial.println( vfo);
  Serial.print(" pllFreq ");
  Serial.println( pllFreq);
  Serial.print("si5351divider ");
  Serial.println(si5351divider);
  Serial.print(" si5351multiCount ");
  Serial.println(si5351multiCount);
  Serial.print(" si5351multi_int ");
  Serial.println(si5351multi_int);
  Serial.print(" si5351nomi ");
  Serial.println(si5351nomi);
  Serial.print(" si5351denomi ");
  Serial.println(si5351denomi);
 // Serial.println(f = vfo / 1000000); // printtaa f 145.XXX.XXX
  if (f < 10)
   lcd.print("");
  lcd.print(f);
  lcd.print(",");
  f = (vfo % 1000000) / 1000; // printtaa taajuuden 3 viim numeroa XXX.550.XXX
 // Serial.println (f = (vfo % 1000000) / 1000);
  if (f < 100)
    lcd.print("0");
  if (f < 10)
    lcd.print("0");
  lcd.print(f);
  lcd.print(".");
 // f = vfo % 1000;
   f = (vfo % 1000) / 100; // removing 2 last digit from frequency reading
 // Serial.println( f = vfo % 1000); // printtaa XXX.XXX.000
 // if (f < 100)
   // lcd.print("0");
 // if (f < 10)
  //  lcd.print("0");
  lcd.print(f); //
  lcd.print("MHz");
 // lcd.setCursor(0, 0);
 // lcd.print(tbfo);
//  Serial.println(vfo + bfo);
//  Serial.println(tbfo);
/* Displays the frequency change step */
void display_radix()
  lcd.setCursor(0, 1);
  switch (radix)
    case 1:
      lcd.print("    1");
    case 10:
      lcd.print("   10");
    case 100:
      lcd.print("  100");
    case 1000:
      lcd.print("   1k");
    case 12500:
      lcd.print("12.5k");
    case 100000:
      lcd.print(" 100k");
    case 1000000:
      lcd.setCursor(1, 1);
      lcd.print("  1M"); //1MHz increments
    case 10000000:
      lcd.print(" 10M"); //10MHz increments
  lcd.print("Hz");
        Serial.println("radix");
       Serial.println(radix);
/* Interrupt service routine for      */
/* encoder frequency change           */
ISR(PCINT2_vect) {
  unsigned char result = r.process();
  if (result == DIR_CW)
    set_frequency(1);
  else if (result == DIR_CCW)
    set_frequency(-1);
/* Change the frequency               */
/* dir = 1    Increment               */
/* dir = -1   Decrement               */
void set_frequency(short dir)
  if (dir == 1)
    vfo += radix;
  if (dir == -1)
    vfo -= radix;
      if(vfo > 150000000)
        vfo = 100000;
      if(vfo < 100000)
        vfo = 150000000;
      if (vfo < 0)
        vfo = 100000;
  changed_f = 1;
/* Read the button with debouncing    */
boolean get_button()
  if (!digitalRead(ENCODER_BTN))
    delay(20);
      while (!digitalRead(ENCODER_BTN));
      return 1;
  return 0;
void setup(void)
   Serial.println(" Hello Word ");  // Put your favourite text here
 // lcd.begin(16, 2);                        // Initialize and clear the LCD
 lcd.clear();
 lcd.setCursor(0,0);
    lcd.print("  OH2BTG ");
     lcd.setCursor(0,1);
    lcd.print("1-150MHz v.0.0.5");
  delay(2000);  //2seconds
  Wire.begin();
  /* Initialise the sensor */
  if (clockgen.begin() != ERROR_NONE)
    while(1);
  /* Enable the clocks */
  clockgen.enableOutputs(true);
    pinMode(ENCODER_BTN, INPUT_PULLUP);
  PCICR |= (1 << PCIE2);           // Enable pin change interrupt for the encoder
  PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
  sei();
  count_frequency();  // Count f and update the display
void loop(void)
 // Update the display if the frequency has been changed
  if (changed_f)
    count_frequency();
  clockgen.setupPLL(SI5351_PLL_A, (si5351multi_int),(si5351nomi),(si5351denomi)); // write si5351ctl divider word
 // clockgen.setupMultisynthInt(0, SI5351_PLL_A, SI5351_MULTISYNTH_DIV_6);
  clockgen.setupMultisynth(0, SI5351_PLL_A,(si5351divider),0,1 );
      changed_f = 0;
  // Button press changes the frequency step
  if (get_button())
    switch (radix)
   //   case 1:
   //     radix = 10;
   //     break;
   //   case 10:
    //    radix = 100;
    //    break;
     case 100:
        radix = 1000;
      case 1000:
        radix = 12500;
      case 12500:
        radix = 100000;
      case 100000:
        radix = 1000000;
      case 1000000:
      radix = 10000000;
      case 10000000:
        radix = 100;
    display_radix();
OH2BTG
I find one error right away here:
volatile uint32_t vfo = 14578750000;// initial frequency in Hz Put your favourite frequency here
two zeros too much, must be:
volatile uint32_t vfo = 145787500;// initial frequency in Hz Put your favourite frequency here
OH2BTG
yo3hjv
Hello Juhanni,
Thanks for the great work!
I made a portable clock generator powered by a LiIon cell.
The battery is connected to Arduino via a small DC/DC converter and the voltage is read via a 2k2 resistor to ADC0.
My LCD is I2C.
Here is the code with respective modifications, maybe someone will find this usefull:
Code: [Select]
//v.1.0.6 09.09.2017 Frequency generator 1...150MHz with 100Hz steps.  OH2BTG
Addons & Mods by YO3HJV
+ I2C LCD
+ Battery voltage indicator on LCD.
feb.2020
#include <Wire.h>
//I2C pins declaration
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const int numReadings = 35;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
float volts = 0;
int inputPin = A0;
#include <Rotary.h>
#include <si5351.h>
volatile uint32_t vfo = 50000000 ;// initial frequency in Hz Put your favourite frequency here
uint32_t radix = 1000; //start step size 12.5kHz
String tbfo = "";
//LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //  LCD: RS,E,D4,D5,D6,D7 Erska
  uint16_t f, g;
 lcd.clear();
  lcd.setCursor(3,1);
  if (f < 10)
   lcd.print("");
  lcd.print(f);
  lcd.print(".");
  if (f < 100)
    lcd.print("0");
  if (f < 10)
    lcd.print("0");
  lcd.print(f);
  lcd.print(",");
 // f = vfo % 1000;
 // if (f < 100)
   // lcd.print("0");
 // if (f < 10)
  //  lcd.print("0");
  lcd.print(f); //
  lcd.print("MHz");
 // lcd.print(tbfo);
  switch (radix)
    case 1:
      lcd.print("    1");
    case 10:
      lcd.print("   10");
    case 100:
      lcd.print("  100");
    case 1000:
      lcd.print("   1k");
    case 12500:
      lcd.print("12.5k");
    case 100000:
      lcd.print(" 100k");
    case 1000000:
      lcd.setCursor(1, 0);
    case 10000000:
  lcd.print("Hz");
ISR(PCINT2_vect) {
    set_frequency(1);
    set_frequency(-1);
  if (dir == 1)
    vfo += radix;
  if (dir == -1)
    vfo -= radix;
      if(vfo > 150000000)
        vfo = 100000;
      if(vfo < 100000)
        vfo = 150000000;
      if (vfo < 0)
        vfo = 100000;
  changed_f = 1;
    delay(20);
      return 1;
  return 0;
void setup(void)
   Serial.println("CLOCK GENERATOR");  // Put your favourite text here
 lcd.begin(16,2);//Defining 16 columns and 2 rows of lcd display
lcd.backlight();//To Power ON the back light
//lcd.backlight();// To Power OFF the back light
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
  {    readings[thisReading] = 0;    }
 lcd.clear();
 lcd.setCursor(0,0);
    lcd.print("  YO3HJV ");
     lcd.setCursor(0,1);
    lcd.print("1-150MHz v.2.0.0");
  Wire.begin();
    while(1);
  sei();
void loop(void)
  voltage();
  if (changed_f)
    count_frequency();
      changed_f = 0;
  if (get_button())
    switch (radix)
   //   case 1:
   //     radix = 10;
   //     break;
   //   case 10:
    //    radix = 100;
    //    break;
     case 100:
        radix = 1000;
      case 1000:
        radix = 12500;
      case 12500:
        radix = 100000;
      case 100000:
        radix = 1000000;
      case 1000000:
      radix = 10000000;
      case 10000000:
        radix = 100;
    display_radix();
void voltage(){
  // subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  readings[readIndex] = analogRead(inputPin);
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings) {
    // ...wrap around to the beginning:
    readIndex = 0;
  // calculate the average:
  average = total / numReadings;
  // send it to the computer as ASCII digits
  float volts = average * (5.06 / 1024.0);
  Serial.println(volts);
    lcd.setCursor (9, 0);
   lcd.print(volts); lcd.print(" V");
  delay(30);        // delay in between reads for stability
73 de YO3HJV, Adrian
