I just installed embedXCode and have it successfully uploading my Star Wars Astromech control program to an Arduino Mega 2560. I have several libraries to run servos and LEDs in real time. The code sense works fine for all of these libraries. However, I cannot get the basic Arduino commands to use code sense (such as Serial.println("Gripper Arm DeActivated")
Additionally, it doesn't seem to recognize procedures if they are defined after the procedure that calls them. I was able to reorder the code to get the sketch to compile. However, this isn't normal behavior. I should be able to declare a function at the end of the file that gets called from the main loop without getting a build error.
For example, using the Arduino IDE this code works and compiles just fine. But in embedXCode I get a "swapPS3NavControllers was not declared in this scope" error.
void onInitPS3(){
Serial.print(F("\r\nGot to onInitPS3"));
String btAddress = getLastConnectedBtMAC();
PS3Nav->setLedOn(LED1);
isPS3NavigatonInitialized = true;
badPS3Data = 0;
//sfx.playTrack("T12 OGG");
trigger.trigger(23);
#ifdef SHADOW_DEBUG
output += "\r\nBT Address of Last connected Device when Primary PS3 Connected: ";
output += btAddress;
if (btAddress == PS3MoveNavigatonPrimaryMAC){
output += "\r\nWe have our primary controller connected.\r\n";
}else{
output += "\r\nWe have a controller connected, but it is not designated as \"primary\".\r\n";
#endif
void onInitPS3Nav2(){
PS3Nav2->setLedOn(LED1);
isSecondaryPS3NavigatonInitialized = true;
badPS3Data = 0;
//TODO:Fix the error when uncommenting line below
if (btAddress == PS3MoveNavigatonPrimaryMAC) swapPS3NavControllers();///<-------Error on this line !!
#ifdef SHADOW_DEBUG
output += "\r\nBT Address of Last connected Device when Secondary PS3 Connected: ";
output += "\r\nWe have our primary controller connecting out of order. Swapping locations\r\n";
}else{
output += "\r\nWe have a secondary controller connected.\r\n";
#endif
void swapPS3NavControllers(){
PS3BT* temp = PS3Nav;
PS3Nav = PS3Nav2;
PS3Nav2 = temp;
//Correct the status for Initialization
boolean tempStatus = isPS3NavigatonInitialized;
isPS3NavigatonInitialized = isSecondaryPS3NavigatonInitialized;
isSecondaryPS3NavigatonInitialized = tempStatus;
//Must relink the correct onInit calls
PS3Nav->attachOnInit(onInitPS3);
PS3Nav2->attachOnInit(onInitPS3Nav2);
I have gone through all of the help files from the embedXCode website about reindexing and manual setup and updating the makefile. I don't know if it matters, but all of the example screen shots show the Arduino icon on the project .ino file while my .ino file has a C++ icon.
Any help would be greatly appreciated. I have spent five days mucking around with this and can't seem to make it work as expected.
