Topic: Programming Reqd - on/off heating control for partially sighted elderly (Read 2238 times) previous topic - next topic
PaulMurrayCbr
Paul.
Please forgive my ignorance, and probably incorrect use of language etc, here, but would it be, could it be 'simpler' in any way shape or form if we were to sit and record complete temperatures (e.g. "twenty one & a half degrees", "twenty two degrees" as individual files so that when a button is pressed and we see a computational outcome of say 21.5 (plus or minus .25 degrees) the reader simply reads file name '21_5'? Hope that makes sense!
We'd only need to record 10 - 30 degrees - so 40 little files. They could then be in a friendly voice rather than some mechanical or 'disconnected' type of voice perhaps less easy to understand. Sorry to be a pain, but just trying to think about how much easier and more comforting it could be with a known voice speaking in a more 'recognisable' way.
Yup - that would be simpler. I'll redo things a little to do that.
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
PaulMurrayCbr
Ok. Change made. Will proceed with the actual buttony bit.
That link again is https://github.com/PaulMurrayCbr/arduino_forum_499650 .
PaulMurrayCbr
Job done.
I mean - as far as I can tell :) . When I press buttons, wiggle potentiometers on my test setup, the LEDs light and messages get sent to serial as the should.
YorkshireDave
Thank you Paul. May your beer be cold and your choice of partner willing :-)
