Topic: HC-SR04 drains all power from arduino uno (Read 721 times) previous topic - next topic
Electronoob123
Hey,
I tried following this guide http://howtomechatronics.com/tutorials/arduino/ultrasonic-sensor-hc-sr04/, i did everything they said, similar code and pins.
I checked multiple times, but when i connect the arduino to the usb with this circut it seems to drain all power from the arduino and shut it off ( the led fades and turns off) when i connect it to the 3.xv instead of 5v it wont work, but the lights of the power will be on and i will be able to downloqd the code.
I bought a new sensor because i thought it was the problem, but i guess not ...
Is the problem with my arduino?
ballscrewbob
Double check the sensor pins are for the function they say they are.
It would not be the first time a sensor has had wrong labels printed on the pins.
You can usually trace the power and ground quite easily to another components sometimes even visually.
"similar" is not the same as "identical" so you may need to supply your own schematic if you have changed anything eg. board or pins etc.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
