Topic: SRAM class using 23K256 (Read 8515 times) previous topic - next topic
carl47
I had a need in a project for a fast easy external memory.
Microchip's 23K256 is ideal.
I looked at Spi Library and Spi RAM  Library from the arduino playground.
What I really wanted was to have the ram accessible continually from my code.
I did not want to pass address and length each time I stored or retrieved data.
My class has four functions:
writestream: Setup the SRAM in sequential write mode starting from the passed address.
                  Data can then be written one byte at a time using RWdata(byte data).
        Each byte is stored in the next location and it wraps around 32767.
readstream:  Setup the SRAM in sequential read mode starting from the passed address.
                   Data can then be read one byte at a time using  byte RWdata(0).The passed data is irrelavent.
         Each byte is read from the next location and it wraps around 32767.
RWdata:      Write or read the data from the SRAM.
                  If the writesteam is open the passed data will be written to the current address.
        If the readstream is open the data from the current address will be returned.
closeRWstream: Use to close the  open read or write stream.
                       Dont need when changing between read/write.
                       Close before using SPI somewhere else.
digital pin 13    SCK
digital pin 12    MISO
digital pin 11    MOSI
digital pin 10    SS
I want it for blocks of data, but it can still be used for individual bytes.
This is the example RWbyte you will find in the library:
Quote
#include <SRAM.h>
Serial.begin(9600);   // initialize serial communications
}//end of setup
SRAM.writestream(22767);  //open writestream address from 0 to 32767
SRAM.RWdata(75); //the byte to write to SRAM at current address
SRAM.readstream(22767);   //open readstream address from 0 to 32767
int data = SRAM.RWdata(0xff);  //read byte from SRAM at current address
Serial.println(data);  //check data
}//end of loop
This example to write and read all 32768 bytes is in the library:
Quote
#include <SRAM.h>
}//end of setup
SRAM.writestream(0);  // start address from 0
unsigned long stopwatch = millis(); //start stopwatch
for(unsigned int i = 0; i < 32768; i++)
SRAM.RWdata(0x55); //write to every SRAM address
Serial.print(millis() - stopwatch);
Serial.println("   ms to write full SRAM");
SRAM.readstream(0);   // start address from 0
if(SRAM.RWdata(0xFF) != 0x55)  //check every address in the SRAM
Serial.println("error in location  ");
Serial.println(i);
}//end of print error
if(i == 32767)
Serial.println("no errors in the 32768 bytes");
}//end of get byte
}//end of loop
If it all works you should see:
116   ms to write full SRAM
For the library and circuit download SRAMclass.zip from:
https://sourceforge.net/projects/mysudoku/files/
philippedal
Hi, Karl. I tried your SRAM, and with some iterations in the proper hardware setup, could have it running, but on a DueMilleNuove.... When I moved to a Mega1280, nothing happens, not even a start of the code, so I suspect some initialization due to SRAM.h does not work... any hint?
Philippe
carl47
#2
Apr 24, 2011, 01:52 am Last Edit: Apr 24, 2011, 02:06 am by carl47 Reason: 1
I'm sorry but I am not familar withn the  Mega1280.
As you say the .h file sets up the pins to use for the interface:
Quote
digital pin 13    SCK
digital pin 12    MISO
digital pin 11    MOSI
digital pin 10    SS
#ifndef SRAM_h
#define SRAM_h
#define setupSPI SPCR = 0x50 //Master mode, MSB first, SCK phase low, SCK idle low, clock/4
#define setupDDRB DDRB |= 0x2c  //set  SCK(13) MOSI(11) and SS as output
#define selectSS PORTB &= ~0x04  //set the SS to 0 to select
#define deselectSS PORTB |= 0x04  //set the SS to 1 to deselect
The 1280 uses different pins for the SPI then you will have to change those.
The 328 uses PB2 as SS (you can use any pin here)
                  PB3 as MOSI
                  PB4 as MISO
                  PB5 as SCK(these 3 are set)
You may also have to change
setupSPI SPCR = 0x50  The SPCR may need a different value.
philippedal
Thanks, Carl. I'll check on that and keep you posted.
Best regards,
Ph
philippedal
Quote
                  PB3 as MOSI
                  PB4 as MISO
Hi, Carl. SPCR are identical on both cpus... So I assume this should not be an issue. Looking further... but what is very strange is that the program seems to lock at the start, no loop info in console... Seems it kind of address some wrong place and hangs.... Ph
carl47
#5
Apr 26, 2011, 09:12 am Last Edit: Apr 26, 2011, 09:17 am by carl47 Reason: 1
I'm sorry I dont have a 1280 or I could give you better answers.
You will have to change the port setup as I have for the 1280:
MISO   PB3
MOSI   PB2
SCK    PB1
As for locking up it could easily happen in:
Quote
byte SRAMclass::RWdata(byte data)
SPDR = data;
 while (!(SPSR & _BV(SPIF)))
 return SPDR;
}//end of RWdata
In the SPSR we wait for the data transfer flag SPIF.
This could be different in the 1280.
OR more likely if you have not set the SPI pins for the 1280 then you wont get a data transfer.
philippedal
MISO   PB3
MOSI   PB2
SCK    PB1
Quote
SPDR = data;
 return SPDR;
}//end of RWdata
Hi, Carl. Problem solved! There is a difference in the DDRB and PORTB between the 168 and the 1280.. so adapting the SRAM.h to cope with the right position of the ports solved the issue. The RAM is now working perfectly on the 1280...:). Thanks for your previous help and support. Ph
carl47
#7
Apr 26, 2011, 11:58 pm Last Edit: Apr 27, 2011, 12:12 am by carl47 Reason: 1
No problem.
Your code for the 1280 could be of help to other forum uses.
How about posting your code at say "code.google". I'm now using this rather than sourceforge
which is now getting very unwieldy.
Or you could just add the code as an attachment to a reply to this post.
You may use all or part of my code without reference.
philippedal
No problem.
Will do for sure... actually code is VERY similar to yours, only 3 lines are modified to cope with the 1280/2560 SPI pinout. Regarding the schematics, it took me a while too, so I will dump a quick scheme. As soon as I have a few minutes.
Once again, thanks a lot for your great help on this.
Philippe
vmarguerie
Hi Philippe,
I try to use the SRAM library with a mega2560 but it does not work for the moment.
I looked at the shematics (Uno and mega2560) and also at the mapping address board http://cna.mikkeliamk.fi/Oppilas/MB210/CV/cvavr/inc/mega2560.h
I changed the following lines in the SRAM.h to match with the mega2560
#define setupSPI SPCR = 0x2c //Master mode, MSB first, SCK phase low, SCK idle low, clock/4
#define setupDDRB DDRB |= 4  //set  SCK(13  52) MOSI(11  51) and SS as output
#define selectSS PORTB &= ~5  //set the SS to 0 to select
#define deselectSS PORTB |= 5  //set the SS to 1 to deselect
The pins I use on the boards are :
#define SCK_PIN   52
#define MISO_PIN  50
#define MOSI_PIN  51
#define SS_PIN    53
Would you please help me to solve this problem ?
Best Regards,
Vincent
carl47
Hi Vincent.
I have not seen anything from Philippe.
He may not be watching this thread.
Try sending a email through this forum.
Cheers.
vmarguerie
Hi Carl,
Just did it. Waiting for an answer now  :smiley-roll:
Hope I will solve this problem.
Best Regards
Vincent
philippedal
Sorry for the delay, was not on forums for a while... overloaded!!!!
So let me try to answer this. I basically used the Carl's splendid work information as it is, with the modification related to the pins assignment, and a very slightly adapted electronic setup (resistors) scheme.
The one I am using is attached in jpeg image. I also pictured the actual implementation which runs perfectly, I use it so temporarily store pictures snapped from a serial camera, before sending those via communications.
The main change is on the SRAM.h file, as follow, to cope with the mega 2560 pin assignments. The changes are as follows:
#define setupDDRB DDRB |= 0x07
#define selectSS PORTB &= ~0x01
#define deselectSS PORTB |= 0x01
Your set is different, so you may have some issue there. The one above is in my SRAM.h and I use it daily, so I guess it is OK...:) The scheme attached is also functional, on a hourly base, never failed once!
For the usage, I took CARL's routine, which work perfectly for me.
Hope this helps. Come back to me if needed.
Ph
All the best.
Philippe
philippedal
Oops... Here is the scheme.... sorry
vmarguerie
Thank you for your help.
I ordered a few resistors required for assembly.
I will keep you informed as soon as I've experienced.
Best Regards,
Vincent
