Topic: [Solved] Board and Port selected but Error says it is not - Create (Read 4235 times) previous topic - next topic
eatonj
Using Create via Chrome and Edge. I select the board and Port and get confirmation, but as soon as I try to upload, Error notification "Please select the board from the dropdown"
I have tried on 2 separate boards Uno R3 and USBdroid both have been working forever. I was downloading to these boards from Create yesterday.
I tried reinstalling the Plugin and rebooting - same issue.
Has something been changed?
ballscrewbob
There have been a couple of reports about this but its a new thing and the staff are away for the weekend.
I will mention it elsewhere see if it can be elevated.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
mula2
ardligthart
Hello Thanks for the good work!!
Same problem here.
When I am trying to upload a scetch on a uno.
Serial monitor works
Thanks
00alis
this issue has been solved, thanks for your patience
ardligthart
sandeepmistry
Hi @ardligthart,
Could you please try to clear the cache on your browser + reload the page and try again.
Thanks.
00alis
also @ardligthart, please try to reselect the board from the dropdown, press change and select the Uno and the port form the popup window, it looks like the metadata got lost for your sketch. Please let us know if this fixes it :)
eatonj
Sorry, I have cleared cache on Chrome and Edge neither are corrected.
00alis
Ok we are able to replicate the issue, that is happening specifically with clones UNO. We will let you know when we have fixed the issues.
Can you confirm you are using a clone?
ardligthart
Hello,
This is Ardligthart
I am using a clone.
I cleared my cache.
The problem is still there.
Thanks!!
Greetings
00alis
Ok we have identified the issue, working on a fix
sandeepmistry
Hi @atrema
I believe a fix has been deployed for this, can you try to re-select the board once more then upload a sketch?
00alis
Yes this issue has been solved last week, are you still experiencing it?
