Topic: [discontinued] Need help for a clock with Parola Double Height (Read 4550 times) previous topic - next topic
marco_c
Use one library or the other, do not use both. You will need to change the code to suit. Please read the documentation to work out what similar functions are for the different RTC libraries.
robiv8
Where can I find the documentation for MD_DS3231?
or otherwise asked!
Where is the code with the RTC.readTime ()
If I would change that then I could omit the MD_DS3231 and the DS3231 use.
Since you say the two back on the same values.
PS.
what I noticed lately, why are standard functions in the code changed so that the existing is not usable. Do not misunderstand, I just want to understand it.
As an example: Can the MD_DS3231 code be more than the DS3231, or why is what own used.?
And thanks for your patience! :-)
marco_c
In the docs folder where you have installed the library (open index.html) and also a link online usually from the displayed README.MD on the repository front page.
For undocumented libraries you need to read the header file to work out what functions are available.
This is a misunderstanding. The only standard functions are those supplied with the arduino official library. Everything else is a contribution by volunteers who do their own work and make it available for others. You will find there are lots of libraries to do similar things with more or less functionality, speed, ease-of-use, etc. As the programmer you need to find one you like and use that.
robiv8
Thanks for trying to help me, but that's too high for me.
I do not know where to start.
Thanks again
Else
Hello
Very interesting clock
Did you solve the problem already?
robiv8
No, since I can not program, I get the problem also not solved.
No matter!
Maybe somebody will have mercy on me sometime and help me. Even though I can not program.
Apart from Marco, he has other things to do than to complete the code. :-)
Is not life-important.
brunogerez
hello I would like to know how you enlarged the lyrics? sorry for my bad english
brunogerez
