Topic: Arduino(Nano) to Water flow Sensor reading (Read 870 times) previous topic - next topic
KhanKAfroze
I connected my water flow sensor to arduino nano. At first i got readings but now i'm not getting it. Reason?
My Connectioin is
Supply module to Water flow sensor
5v --> Vcc
Gnd --> Gnd
Arduino to Water flow sensor
D2 --> Signal
And my code is
Code: [Select]
void setup(){
  }[b][/b]
void loop(){
 int vla=analogRead(2);
 Serial.println(vla);
 delay(1500);
Is there something which i'm missing
Wawa
D2 --> Signal
And my code is
So you connected the sensor to D2,
and you're reading pin A2.
Leo..
pert
Also asked at https://arduino.stackexchange.com/q/44976
If you're going to do that then at least you could be considerate enough to add links to the other places where you posted your question. It would have saved Wawa the trouble of giving the same answer I already gave you on Stack Overflow.
