Topic: INA3221 breakout board  (Read 10266 times) previous topic - next topic
Wangas
I have purchased a INA3221 breakout board from eBay to replace several INA219s. They differ from the switchdoc INA3221 breakout board and the INA219 in having no V+ and V-. Instead they have three channels with CH1/2/3 and GND. I have tried to connect these pins as V+ and V-, but there is no current. The CH channels seems connected as I can put V+ on one and V- on another channel and get voltage and current readings on both, but with reversed current direction.
The POW pins also connected to the CH pins. I can put V+ on POW and measure voltage and current on all three CH pins when connecting V- to those.
Have anyone has any luck using these sensors? Any good advice for hooking them up?
The module: http://www.ebay.com/itm/INA3221-3-Channel-Shunt-Current-Voltage-Monitor-Sensor-Replace-INA219-Module-/262946505125
MarkT
That module doesn't bring out the 3 pairs of sense pins separately, it cannot be used as a high-side
current sensor, only low-side.  Ground is used as the return for all channels.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
Wangas
That is what I suspected. What a pity....  Guess I have to buy the Switchdoc module.
Wangas
The description of the module is somewhat misleading......
The INA3221 is a three-channel, high-side current and bus voltage monitor with an I2C- and SMBUS-compatible interface. The INA3221 monitors both shunt voltage drops and bus supply voltages, in addition to having programmable conversion times and averaging modes for these signals. The INA3221 offers both critical and warning alerts to detect multiple programmable out-of-range conditions for each channel.
The INA3221 senses current on buses that can vary from 0 V to 26 V. The device is powered from a single 2.7-V to 5.5-V supply, and draws 350 µA (typ) of supply current. The INA3221 is specified over the operating temperature range of -40°C to +125°C. The I2C- and SMBUS-compatible interface features four programmable addresses.
I have attached some pics of the module and datasheet for the IC for reference.
Wangas
Front pic attached.
Wawa
it cannot be used as a high-side current sensor, only low-side.  Ground is used as the return for all channels.
True.
Are you sure about that.
I see one side of all shunts connected to a common via.
And the other sides of the three shunts to individual vias.
No ground connection to the shunts.
This board can only be used for high-side sensing of three loads connected to a common supply.
Not even sure if the chip is bi-directional (like the INA219).
Couldn't find it in the datasheet, so I assume it's not.
Leo..
MarkT
Look carefully at the pictures - 3 of the 6 holes are linked to the groundplane.
Wawa
#7
Sep 25, 2017, 12:43 pm Last Edit: Sep 25, 2017, 12:55 pm by Wawa
True.
But the three shunts are connected to the other three holes.
And shunt common goes to a different hole on the side of the board.
It seems that this board is designed for three loads, connected to those six "power/ground" vias.
And that 'power-in/ground' is on the side of the board.
I wonder how much current those thin shunt traces can take before evaporating.
Leo..
Wangas
I thought I'd reach out to the sellers of this module to see if they could provide some useful information.....
Great customer support from chinese eBay and AliExpress stores :)
I will set up a test this afternoon with testloads on the three channels and try it high side and low side to see how that works out.
New message from: deepenmind (13,797YellowShooting Star)
Thanks for your email.
Sorry, I am just a customer service.
I tried my best to found some information for you, but sorry have no result.
We actually have no enough technical information can offer.
I hope to get your understanding.
Do you mind searching information online to find more technical support?
Thank you.
Best regards.
New message from: alice1101983  Top Rated Seller(372,646RedShooting Star)
Dear friend ,
Sorry , I am just a customer service.
I tried my best to found some info for you ,but sorry have no result.
We actually have no enough technical information can offer .
Do you mind searching information online to find more technical support ?
Thank you .
Best regards .
xiao meng
17/09/24 23:47
Dear friend ,
Thank you for your email .
But sorry that I am not sure about it.
I can make sure that our items are as shown in the figure and item's description .
If you need any help ,
Pls contact me anytime .
Best regards .
Arduino China
17/09/25 02:23
Dear friend,
For more detail you can find it on our item description.
Do you mind finding it or searching information online to find more technical support?
Your understanding will be highly appreciate.
Best regards.
zhang tao
17/09/25 03:32
Dear friend ,
Best regards .
MarkT
True.
Leo..
Ah, that could be.  The original chip doesn't restrict you to a common supply for each shunt, so
I'd expect it just to be wired in line with the high side supply separately per channel.
MarkT
Or put another way the board isn't breaking out the chip connections in the way the datasheet would
imply would be obvious.
Wangas
#11
Sep 25, 2017, 09:28 pm Last Edit: Sep 25, 2017, 09:46 pm by Wangas
I have tested the module tonight. It is definitively a high side sensor as described in the datasheet. I did a low side test just to be 100% sure. See the attached photo of the setup and the load reading. I used a computer controlled load and tried to draw 1 amp.
Wangas
Here are the results of the high side testing. The module will, as Wawa described, let you measure three loads on the same power supply. I have attached the setups and readings from the different channels, and a setup with two loads. The negative current readings is due to the code and can easily be changed. But is was programmed to show a negative reading for current going into the battery and positive for current coming from the battery.
I have also made a small tutorial to help the next guy whose scratching his head over this module: https://youtu.be/n9tnBJ0_Rxw
Wangas
Here's the rest of the screencaps of readings.
MarkT
Glad it works - I suppose limiting it to a single supply saves on board area, but its a shame as the chip
is designed to sense upto 3 different rails for power consumption...
