I have been using an FTDI chip and an Arduino Pro Mini 328P 16Mhz 5v for a while now. I have 4 of the Pro Minis and I have 4 of the FTDI chips. I have been working on a sketch for over a week. I have been uploading and changing sketches with no issue.
Suddenly tonight, for some reason, I started getting this error:
Arduino: 1.6.9 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Sketch uses 2,186 bytes (7%) of program storage space. Maximum is 30,720 bytes.
Global variables use 252 bytes (12%) of dynamic memory, leaving 1,796 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0xff
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xff
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I have tried just about every combination of FTDI chip to Pro Mini. I will get one to start programming, and then that combination will start getting this same error.
I saw the comment about "This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences." so I turned it on and tried again. I will post that next.
I am stuck. What could be causing this?
Here is the more information:
{......file information removed for space..........}
C:\Users\admn\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\admn\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\admn\AppData\Local\Temp\build78f78a6232a4893264ba9c993ef764ca.tmp/BackLedTiming.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\admn\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\admn\AppData\Local\Temp\build78f78a6232a4893264ba9c993ef764ca.tmp/BackLedTiming.ino.hex"
avrdude: writing flash (2186 bytes):
Writing | ################################################## | 100% 1.14s
avrdude: 2186 bytes of flash written
avrdude: verifying flash memory against C:\Users\admn\AppData\Local\Temp\build78f78a6232a4893264ba9c993ef764ca.tmp/BackLedTiming.ino.hex:
avrdude: load data flash data from input file C:\Users\admn\AppData\Local\Temp\build78f78a6232a4893264ba9c993ef764ca.tmp/BackLedTiming.ino.hex:
avrdude: input file C:\Users\admn\AppData\Local\Temp\build78f78a6232a4893264ba9c993ef764ca.tmp/BackLedTiming.ino.hex contains 2186 bytes
avrdude: reading on-chip flash data:
### | 100% 0.97s
avrdude done. Thank you.
Maybe a little late now , but I managed to get arid of this error , by using an USB 2 port instead of a USB 3 port
Regards
