Arduino Forum
Using Arduino
Microcontrollers
ATMEL ATTINY85 - How to switch clock to 128 kHz or less?
Print
Pages:
1
[2]
Topic: ATMEL ATTINY85 - How to switch clock to 128 kHz or less?
(Read 3561 times)
previous topic
next topic
mpcz
Newbie
[add]
Re: ATMEL ATTINY85 - How to switch clock to 128 kHz or less?
#15
Oct 16, 2017, 06:28 am
Hello,
upload to TINY85:
avrdude -B250 -c usbasp -p t85 -U lfuse:w:0x04:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m ....
The base frequency is reduced. 8x division does not work.
Where is the error?
Thanks, mpcz, 16.oct.2017
Smajdalf
Edison Member
[add]
#16
Oct 16, 2017, 01:51 pm
Maybe you chande main clock prescaler in your code?
How to insert images:
https://forum.arduino.cc/index.php?topic=519037.0
mpcz
Newbie
[add]
#17
Oct 16, 2017, 01:57 pm
Last Edit
: Oct 16, 2017, 02:03 pm by mpcz
Yes, the change in code "clock/8" works OK.
I need a change of "frequency and divider" via FUSE.
mpcz, 16.oct.2017
Smajdalf
Edison Member
[add]
#18
The fuse sets prescaler to divide by 8. If you change it via code later the value from fuse is overwritten. I.e. if it is set by fuse to 8 and you set it to 8 too you get total prescaling 8 (~16kHz), not 64 (~2kHz). Isn't this your problem?
mpcz
Newbie
[add]
#19
Oct 16, 2017, 02:10 pm
Sorry, I do not understand.
I set fuses:
The code is empty. Frequency is 128k, not 16kHz.
What is wrong?
Thank, mpcz, 16.oct.2017
Smajdalf
Edison Member
[add]
#20
Oct 16, 2017, 02:15 pm
Are you sure the code is empty? Are you sure no core/bootloader is present that sests the prescaler to 1? Try to add
-e
command line option to the avrdude command to erase possible remnants from the chip.
DrAzzy
ATtiny Obsessee
Shannon Member
[add]
https://www.tindie.com/stores/DrAzzy/
#21
Oct 16, 2017, 04:53 pm
How do you know that it's running at 128khz?
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store
http://tindie.com/stores/DrAzzy
mpcz
Newbie
[add]
#22
Oct 16, 2017, 09:02 pm
I have an ocsiloscope attached to pin # 3, there is an output clock.
mpcz, 16.oct.2017
Smajdalf
Edison Member
[add]
#23
Oct 16, 2017, 09:32 pm
Last Edit
: Oct 17, 2017, 06:22 am by Smajdalf
How do you know the code is empty? Did you erase the chip? Try to read flash to be sure it is empty.
DrAzzy
ATtiny Obsessee
Shannon Member
[add]
#24
Oct 16, 2017, 09:33 pm
Sanity check...
Upload blink to it via ICSP, compiled for 128khz. Does it blink for 1 second or for 8 seconds?
I agree with your assessment though, it should be outputting - and running at - 16khz!
I would also consider trying to set the prescaler from the application (or at least read it out and blink an LED that many times, or something...)
Print
Pages:
1
[2]
Loading...
