Topic: PID rules can be changed! (Read 9878 times) previous topic - next topic
Southpark
#30
Oct 31, 2017, 10:21 pm Last Edit: Oct 31, 2017, 10:27 pm by Southpark
that's right using accelometer will make it auto level .......
but  i found that its stabilized while flying ..... so for that i said gyro stabilizes the drone.....
It is ok that your UAV doesn't use accelerometers. It's just that it won't have relatively long-term self-stabilising capability when you take your hand away from the joystick. If your system works for you, then that's great.
adelphysi
the main idea of all is that PID may change , consider  that drone stability is like those with just gyro ....not more
but PID in mine is just about gyro values no more.....
