Topic: arduino big LED matrix with MAX7219s or 74HC595s (Read 2469 times) previous topic - next topic
piticasgabriel
Hello All!
I hope someone will help me in this new forum! My school require me to build a 32x8 (or biger) matrix LED display, a single color, to display animations, clock and date (with DS1307), indoor and outdoor temperature (with 2 digital sensors DS18B20), humidity (with SYH-1 sensor), EEPROM 24LC256, switches or encoder etc... I prefer to use  MAX7219 but I think they will accept and 74HC595 in project ... Someone has done something? Or something similar? I need the code, please!
Thank you!
JanD
http://arduino.cc/playground/Main/LedControl a library to use with MAX7221/MAX7219. With this you can easily drive all leds.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1191209057/0 a library to use with DS1307.
http://www.ogalik.ee/node/23 setup and link to a library to read from DS18B20 temperature sensors.
Couldn't find a library for the SYH-1 :(
http://10kohms.com/arduino-external-eeprom-24lc256 tutorial on how to use the 24LC256 with arduino.
http://www.arduino.cc/playground/Main/RotaryEncoders a tutorial on how to use encoders with arduino.
http://www.arduino.cc/playground/Code/Bounce a library for debouncing buttons.
So, I think you are going to go through these links for some time. Then you're done I think you have some ideas.
Jan
P.S. If you are going to use all the above things I think you are going to need to use an Arduino Mega or Sanguino. Not only because of the code, even because you are going to need "some" pins.
gilmoret
Take a look at these boards from Sure Electronics. Many users have used these on this forum so a good search for code should not be too hard and can be used with any micro-controller including the Arduino.
http://www.sureelectronics.net/category.php?id=60
piticasgabriel
   Hello and thanks a lot Jan and Tim!!!
Hopefully someone can help me with some code similar to what I need ... I don't have time to learn to program well in Java, to combine and to modify some codes. After school, I work until late at night ... This is something normal in Romania. My school require 5mm LED array with 1 cm distance between LEDs, custom made with hi-bright general purpose clear LEDs. The matrix from Sure have 3mm LEDs.
Thank you again!
JanD
Thank you again!
1. Arduinos are programmed in a C/C++ like language, not Java.
2. Help? I think this forum is the best you can find for that.
3. A custom LED matrix, huh? What's going to make things harder. But 32x8 = 256 LEDs = 4 MAX7219/MAX7221.
This is going to be an interesting project, and I can almost guaranty you what you are going make it. It will not be too easy but as sad, completely doable.
Jan
gilmoret
Piticasgabriel,
The link I posted before was to show you the many types of displays that Sure Electronics have some in just 3 mm LEDs and others in both 3 mm LEDs and 5 mm LEDs.
Currently I have 4 working displays and hope to have 8 of them working together of their 5 mm type for the 3216 RG displays by Sure Electronics.
http://www.sureelectronics.net/goods.php?id=1122
You really want to utilize premade LED matrix modules with LED driver chips already installed and ready to just connect up to a micro-controller like an Arduino. If you must design your own LED display board with a custom printed circuit board and individual LEDs, it will be very time consuming and expensive.
Let us know if you have any other questions or require further details.
piticasgabriel
Hi!
   Finaly, I will insist with MAX7219 because is easy to find/import in Romania, is not very expensive and is a great chip. And I prefer to make a hard job for a great satisfaction!
I observe that many avoid using more than one MAX7219 and I don't understand why?
Awaiting your opinions and suggestions!
florinc
A 595 shift register is almost 10 times cheaper than MAX7219. You will need either one of these chips for each 8x8 single color LED matrix. Therefore, for a 8x32 LED matrix, you will need either 4 x 595 (plus an ULN2803) or 4 x MAX7219.
MAX7219 can be daisy-chained, according to the data sheet.
