Topic: New library for RF22, RFM22 radio modules (Read 30683 times) previous topic - next topic
MarkT
Just a quick question:  Does the library only support the RFM22 or does it cover the RFM22B as well?  And RFM23 and RFM23B (lower power versions)?
MarkT
Actually another question:   From what I can make out of the RFM22 documentation you need to control the TX_ANT and RX_ANT pins to switch the antenna to the right pins on the chip depending on if transmitting or receiving.  There seems to be no mention of this in the code or docs AFAICT - I guess this is because the package isn't assuming a particular module, just the RF22 chip.
However the RFM22 module is probably rather dominant in the RF22 market, it would be good to support it...  Or have I missed something here?
mikem
According to http://arduino.cc/forum/index.php?topic=50417.0 and to my tests, the tx_ant and rx_ant pins arent needed. I leave them floating and it seems to work fine.
MarkT
Ah, I'm wondering if this is a difference between the DIP and SMT versions of the RFM22.  The SMT version I have definitely have an antenna switch chip (6 pin near ANT) that must be driven correctly.  However I suspect all the RFM22 modules have this as the chips RX side can't survive the full output power from the TX side (17dBm) without a switch according to the documentation.  By contrast the lower powered RFM23 doesn't have one.
If the pins are left floating its unlikely you'd get any appreciable power off the device (limiting the range greatly) - there's also a risk of generating harmonics that splatter over other bands, which is not a good thing.  There is also the risk of burning out the PA at full power since the VSWR will be badly off.
mikem
The ones Im using are identical to the one in the picture at:
http://www.sparkfun.com/products/10153
If it really needs tx_ant and rx_ant pins to be controlled externally, then I will need to make some changes to the library.
But... surely the controller chip on board knows when it want to transmit and recieve and should be controlling the antenna switch itself? Why would it expect an external processor to control the antenna switch for it?
Cheers.
MarkT
The datasheet suggests using GPIO0 and GPIO1 to control them - GPIO's can be set to the TXstate and RXstate for instance or directly controlled via SPI.   Its worth checking which modules have a switch (I'm suspecting its 22's and not 23's but I don't really trust the datasheets as they seem to cover the silicon only with module information as an afterthought)
Have you seen a 22B or 23B BTW?
mikem
The ones Im using are RFM22B-S2 as per the sparkfun page:
The data sheet for that one at:
http://www.sparkfun.com/datasheets/Wireless/General/RFM22B.pdf
does not mention tx_ant or rx_ant at all. The table on page 64 has 'NC' in hte places where there was  tx_ant and rx_ant on the RFM22.
So looks to me like they are not connected in the RF22B.
lemming
Cheers.
As you state, it does seem strange that we have to manually switch these pins when the chip knows that it is going to transmit or receive. Doesn't make sense!
However on page 62 of ver 1.1 of the HopeRF manual it states:
"Tx Antenna select input pin, When RFM22 is TX state,TX_ANT should be = 1, RX_ANT should be = 0"
and
"Rx Antenna select input pin, When RFM2 2 is RX state,RX_ANT should be = 1, TX_ANT should be = 0"
Whether these are asserted through the GPIO pins of the RFM22B or by the I/O of the Arduino is left to us, but either way they need to be toggled by the program.
mikem
The RF22 library was written for the RFM22B devices and AFAICS, the tx_ant and rx_ant pins dont need to be connected for the RFM22B. May be different for the RFM22 devices, but RF22 library does not support them.
lemming
If you go to http://www.sparkfun.com/datasheets/Wireless/General/RFM22B.pdf you will find version 1.1 of the 22B-23B manual.
(strangely this is a more up to date version than that on the HopeRF site which is version 1.0).
On page 58 of this manual there is Figure 32A it clearly shows TX_ANT and RX_ANT connected and on page 62 it refers to asserting them. The confusing part is that they roll the 22B and 23B manual into one. The 23B does not have these pins and therefore they are not discussed in reference to this module. It is a bit confusing as to when they are talking about one module or the other.
I will send off an email to HopeRF to get a definitive answer.
mikem
lemming, yes I see your point.
Let me know what Hope says. If I need to make changes to the lib I will.
Cheers.
FrankRadio
I think that the two antenna outputs got a reason, and is not about who antenna transmit and who receive.
At radio systems you got a coverage problem when the frecuencies goes very high, and this situation do not correct using more power at the transmiter or at the receiver. This is an signal angle problem and is so complex that the signal loose all the power is like it pass for virtual 0 degree and loose itself.
The only way to correct this situation is use another antenna equal to the first but in a different polarization angle, at cellular systems they use a second receiver w/a second receiver antenna to correct this sum both receivers signals.
At the PDF the diversity antenna algorithm is included on the chip firmware, but the antenna switch is external via PIN/GAS diodes, this antenna switch is controlled via the GPIO PINS, that means that this SW is EXTERNAL and is not included on the RFM22/23 PCB.
Build a antenna SW at this frecuencies will be very hard!
Best Regards
Frank
MarkT
Ah that explains it - haven't seen RF22B silicon myself.
For the RFM22 all that's needed to support the pins is
Code: [Select]
    spiWrite (RF22_REG_0B_GPIO_CONFIGURATION0, 0xD2) ; // TX state
    spiWrite (RF22_REG_0C_GPIO_CONFIGURATION1, 0xD5) ; // RX state
And then connect GPIO0 pin to TX_ANT and GPIO1 to RX_ANT as in the RFM22 datasheet.
The RF22B's lower power levels mean its matching network doesn't need to be isolated from the RX input during TX as it can take the power levels without frying.  For the RF22 this isn't safe at high powers (17dBm is 4.5V p-p into 50 ohms) hence the antenna switch chip on the RFM22 module.
FrankRadio
#28
Aug 11, 2011, 08:01 pm Last Edit: Aug 11, 2011, 08:04 pm by FrankRadio Reason: 1
From the module, the Tx/Rx switch is inside the silicon.
Now for the atenna diversity application, the chip don't have built-in the antenna switch, you MUST build this polarization switch external to the RFM22 device.
The control from this switch is made via GPIO outputs, the inputs TX-ANT and RX-ANT is like a SDPT-SW sensor, because the radio can be used for high speed radio links, the radio must know when the SPDT switch is ready to transmit, i mean when the selected antenna is successfuly connected
Quote
8.9. Antenna Diversity
To mitigate the problem of frequency-selective fading due to multi-path propagation, some transceiver systems use a scheme known as antenna diversity. In this scheme, two antennas are used. Each time the transceiver enters RX mode the receive signal strength from each antenna is evaluated. This evaluation process takes place during the preamble portion of the packet. The antenna with the strongest received signal is then used for the remainder of that RX packet. The same antenna will also be used for the next corresponding TX packet.
This chip fully supports antenna diversity with an integrated antenna diversity control algorithm. The required signals needed to control an external SPDT RF switch (such as PIN diode or GaAs switch) are available on the GPIOx pins. The operation of these GPIO signals is programmable to allow for different antenna diversity architectures and configurations. The antdiv[2:0] bits are found in register 08h "Operating & Function Control 2."
The GPIO pins are capable of sourcing up to 5 mA of current, so it may be used directly to forward-bias a PIN diode if desired.
This idea is widely used on high speed radios.
mikem
OK, I have modified the library so that GPIO0 and GPIO1 are set to follow tx_state and rx_state respectively, and updated the doc to show connections from GPIO0 to TX_ANT and GPIO1 to RX_ANT.
After doing this I saw abut 5 db higher output on transmit at higher levels with my RFM22B-S2
New version 1.7 of RF22 library is now uploaded.
Feedback please.
